20 Most Recent
Spirit Esprit by ET-6 Folding Treadmill Questions & Answers
Low speed L5 keeps showing up and shutting it down
L5 or LS is short for Low Speed error. It basically means that the speed sensor is not picking up a signal. Unfortunaly its a pretty vague error code and can be caused by several different problems
First you have to determine weather or not you have belt movement. If you have a LS with belt movement you know that it is related to the speed sensor itself (or the MCB motor control board - the part of the MCB that handles speed sensing function). If you are getting an LS w/belt movement you have to check to see if you have power output from the MCB. If you have no power output, check fuses, if fuses are good you will need the MCB replaced. If you have suffcient output it
drive motor related. Aside from a problem with the drive motor, it is possible that another factor is stopping the motor from turning (locked up roller bearing, foreign debris, etc.). If it is a case of faulty electronics the next question is, is to figure out what cause it to fail. Most MCBs don't fail on their own, something unusual causing them to fail. The bottom line: The LS error can be complicated and should really be inspected by a professional to fully access the issue. Cost to repair can vary greatly depending on what exactly is wrong with it. Also keep in mind, if the unit is covered
under warranty, tampering with it most likely will void it.
Free spirit club FS200
Could be that the belt has stretched and it needs to be retightened or replaced with new one.
