20 Most Recent Precor EFX 546i Elliptical Version 4 Questions & Answers
Sorry to say its time to replace the belts You may purchase them directly from Precor @ 1-800-347-4404 or
http://www.gympart.com or http://www.sportsmith.net
Have your serial number
Precor EFX 546i... | Answered on Oct 28, 2017
Replace the battery
Book An appointment
Precor EFX 546i... | Answered on Apr 23, 2016
Someone needs to look at this as noise issues can be from anywhere and anything.
877-805-1030
Book An appointment
Tip it over - there was a version that had a problem with the frame cracking where the ramp attaches. There is a kit to fix this, if that is what you find.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
Precor EFX 546i... | Answered on Mar 27, 2016
Using your model and serial number, use this link to view a service manual with procedure instructions.
http://www.sportsmith.net/
Precor EFX 546i... | Answered on Feb 25, 2016
You may have to purchase the belt from a Precor dealer in you area, if you don't have one then call Precor directly @ 1-800-347-4404 and they will help you. Most of these part have not hit the secondary market yet and Precor pretty much call the shots.
Precor EFX 546i... | Answered on Jan 22, 2016
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH Warning Notice for Battery Installation of certain Precor Ellipticals This notice provides details about the battery replacement procedure that should be considered by anyone performing this repair. Following is the warning about the battery installation for certain models of the Precor ellipticals.
Precor Elliptical Models Affected:
  • EFX C524 with serial#s beginning I7, K7, LH, SW, SX
  • EFX C546 with serial#s beginning NF,SZ, IK, IL, IU
  • EFX C546I with serial#s beginning X8, XG, Z2
  • EFX C556 with serial#s beginning NG, SY
When replacing the battery on your Precor elliptical it is important to make sure that the battery terminals are not allowed to make contact with the metal surface of the battery bracket. **Damage to the battery will occur**.
Electrical tape can be wrapped around the battery terminals to prevent them from making contact with the metal surface of the battery bracket.
Battery replacement on the EFX C524, EFX C546, EFX C546i and EFX C556 instructs you to remove the (4) screws that fasten the battery bracket to the frame. This allows you to turn the lower PCA and battery assembly away from the frame so you can slide the battery out of the battery bracket. It may be necessary to remove the nut that fastens the front retaining bracket or "L" bracket in order to slide the battery out of the battery bracket.
Warning Notice for Battery Installation on Precor EFX Ellipticals
Precor EFX 546i... | Answered on Oct 29, 2015
This is commonly caused by a bad overlay/keypad. The only solution to resolve this issue is to replace the overlay/keypad.
Please use your model and serial number to find the correct replacement at the following link: Precor Equipment Repair Parts Treadmill Belts Ramp Sleeves SPORTSMITH net
Start by checking the voltage output from the battery. I am attaching a link to a video with instructions on how to test a battery.
Video about How to Test Battery
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH You can find the overlay and keypad on our Website, using your model and serial number.
Precor EFX 546i... | Answered on Sep 28, 2015
It doesn't always say low battery - check the battery first. If the battery is fine, then check the lower board and the incline motor.
Precor EFX 546i... | Answered on Jun 09, 2015
You definitely can but you'll have to buy a 12V lead acid battery charger, the best option for a dead battery is just replacing it. With lead batteries there is a chance you'll get it to charge once and it'll just go dead again.
Hope this helps!
If you need a replacement battery for your machine, we do carry them, I will be attaching a link
http://www.sportsmith.net/itemform.aspx?item=P0612258070&ReturnUrl=/productsearch.aspx?dsNav=N%3a11565
I would definitely check the battery first. The battery may not have enough charge to power everything plus the lift motor.
Here's a link to the various 546i models:
Repair Parts for Precor EFX 546i Ellipticals SPORTSMITH net
Drill it down on the left side under "narrow your search" and look for the serial number prefix. This will let you find all the correct parts and information specific to your model and serial number.
Precor EFX 546i... | Answered on Apr 02, 2015
Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor EFX 546i... | Answered on Jan 28, 2015
Precor EFX 546i Elliptical Version 4 Logo
232 questions posted
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Howard
Howard
Jose Pino
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Precor Exercise & Fitness
Most Popular Question
looking repair manuals error codes
  • Exercise & Fitness
