20 Most Recent
Electrolux EOB5630 Ultrafan Electric Single Oven Questions & Answers
Electrolux EOB5630X. Oven works fine
the electronics are heating up and cutting out.that cold be a bad clock assy. or there's a fan in there that could be bad or i've seen on some models there's a screen in where the fan is,it gets clogged with dust and the air can't blow to cool down the electronics.if it is the fan and you keep using it like that it will take out the computer board or clock assy. same part.
Electrolux EOB5630 door hinge locked closed
Look for a release button. If not, it may have a locking mechanism that needs to be released. Try some of these: push the hinge to one side while lifting, press the hinge down then lift, pull up on the hinge while pulling. Good luck!
How many elements are there
If you ask how many heating elements is there then my answer is two. Upper heater element with grill heater (1000 / 1900W) and ring heating element (2400W) that is positioned around the convection fan.
Dado
I have a faure oven
press and hold the temperature button and simultaneously hold the 'temperature duree' knob to the + or - position until you hear a beep. This locks and un-locks the child safe mode
What is the diference between
I would guess they are the same element
in Australia the last letter in electrolux ranges signifies the color or type of clock fitted the B would be for Black ovens the X would be a multi function oven they all have the same fan element
Eob5630w oven shutting down before set temp
The reason the oven is shutting down is because it is overheating due to the cooling fan not working, and a safety thermostat is turning the oven off.
You need to repair or replace the exterior cooling fan.
The fan works but there is no heat
The problem is usually caused by a faulty oven element.
This is usually located at the rear of the oven compartment, behind a removeable cover.
Hope this helps.
Using my EOB5630 oven went bang
the fan element will have shorted out. if you remove the panel from inside the oven you may see where the circular fan has shorted. It will have blown a fuse poss in a plug if connected that way.or tripped a circuit breaker. remember to set the clock when power is restored as it wont work until you do.
