20 Most Recent
991 Responder LC3 SST Security/Remote Start System Questions & Answers
Remote start work but door will not unlock or lock!
Do the doors unlock when the remote starter is not running? If so, then you to connect to a different set of door lock wires.I usually connect to the factory alarm and disarm wires in the driver kick panel. They are blue for arm and pink for disarm. You test them by turning the key in the drivers door.
When i try and use the remote start, it doesnt
The parking lights will also flash a number of times to inform you of the error. The most common causes of the error are neutral safety shutdown (7 flashes). This is the toggle switch under the dash. Locate said switch and toggle it to the on position. Six flashes is the hood pin switch. Locate the switch under the hood and make the necessary adjustment so the pin makes contact with the hood when the hood is closed.
I have a 2005 Subaru Outback with the Python 911
Hello Ihemker,
I understand that you are having a problem with you Python 991 system. The problem is that you front and rear parking lights are not turning off when the alarm is set. Python does not have a suggestion as why this is happening. However, usually resting the system will revert the system to the last good setting.
The system needs to be rest. You can disconnect the car battery for five minutes. The security system has a back up battery that will save the settings of the alarm. If this does not work you will need to take it the a dealer and have them reset the unit.
Thank you for choosing FixYa.com
Justin
Battery on Python 951 control
The plug of the remote is similiar to many cell phone chargers. They can also be charged with a USB cable connected to a computer.
I'm trying to install a Python 991 Remote Start /
It is not the "control center" that needs to be switched. The unit itself must be programmed for automatic transmission. The antenna (control center) must be connected to the module for normal operation. Merely connecting the two does not initiate a reaction from the LED. You MUST enter the programming mode (ignition on , ignition off, press and hold programming button until you hear three chirps from the siren). The three chirps are remote starter programming options. After you hear the three chirps, press and release the programming button once then, press and hold the button (you will hear one confirmation chirp), now press and release the lock button on the remote (you should hear two chirps from the system). The unit is now programmed for automatic transmission.
There are several other programming options for your particular vehicle (not mentioned) that may be NECESSARY for the proper operation.
How do i get the security system out of valet
From remote: press F twice on the remote then unlock. (F, F, Unlock)
From car: have door open, turn key to ignition position (ON), then OFF, then press and release the button on the control center (antenna on the windshield).
hope this helps.
