20 Most Recent 477L Ask RXTX HHU Remote Questions & Answers
Hi This is an earth problem you need to ensure your starter is earthed properly or renew the earth cable is best this should solve the problem. Please leave me feed back: Malcolm Campbell, Thanks.
477L Ask RXTX... | Answered on Dec 03, 2017
Open door, turn ignition on, press and release programming switch one time, press and hold programming switch while pressing lock button on remote. You should hear a confirmation chirp from unit.
477L Ask RXTX... | Answered on Apr 03, 2016
Check fuses on control box. Make sure it is not in valet mode.
477L Ask RXTX... | Answered on Jun 06, 2014
You will need to get the model number from the main module under the dash, not off the remote.
477L Ask RXTX... | Answered on May 14, 2014
install like a regular remote start alarm. You will have to tap into the glow plug wire, and change the setting on the brain to "wait to start" for the glow plugs.
If you have not installed a remote start alarm before:
1.install the siren under the hood and run the wire through the fire wall into the cab.
2. Mount antenna at the top center of the windshield then run wire around and down to drivers floor.
3. mount shock sensor with a ziptie to the steering column (as long as the steering column doesn't move/rotate)
4. separate the wires you are going to need, from the ones you won't need.(specific per vehicle):12+, Gnd, Parking lights, IGN, IGN2, ACC, ACC2, Starter, lock, unlock, brake, glow plugs...
5. zip tie and tape off the unused wires.
6. use wire diagram and find then test the vehicle wires.
7. connect RS/Alarm to vehicle, plug in antenna and shock sensor, then attach siren.
8. BEFORE DOING ANYTHING ELSE-GO INTO PROGRAMING AND CHANGE THE SETTING FOR A DIESEL !
9. now you can test the functions of the RS/Alarm,
BE SURE TO KEEP A WINDOW ROLLED DOWN, OR HAVE A SET OF KEYS OUTSIDE THE VEHICLE!
477L Ask RXTX... | Answered on Apr 14, 2014
Sounds like a bad ignition switch.
477L Ask RXTX... | Answered on Feb 21, 2014
im willing to bet your mechanic seen a wire he didnt think belonged there and just cut it (happens all the time with aftermarket electronics)
477L Ask RXTX... | Answered on Mar 09, 2011
The Zs mean that the alarm is in valet. To exit valet with the remote: open any vehicle door, press lock,unlock,lock. The zs should disappear from the remote allowing you arm the alarm.
477L Ask RXTX... | Answered on Feb 16, 2011
477L Ask RXTX HHU Remote Logo
Popular Tags
40 questions posted
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
baire
Billy Mac
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Avital Vehicle Parts & Accessories
Most Popular Question
avital 477l starter
  • Vehicle Parts & Accessories
