20 Most Recent Gateway SX2110G-UW318 Small Form Factor Desktop PC with AMD E1-1200 Questions & Answers
Sometimes updates running in the background act that way. You can wait it out (could be 1/2 hour or more depending on how many updates) or you can try holding "ctrl", "alt" and tap "del" key and see if "task manager" opens up. If it does, it should show what processes and applications are running. That may give you a clue. Finally, you could just hold the power button down a few seconds until it shuts down. Upon restart, you may have to select an option such as "start normally". If you continue to have problems after the restart you may need to go into "system restore" mode (type "system restore" (w/out quotes) in search box of Start menu, follow the prompts and choose the restore point just before the last system change.
Gateway... | Answered on Oct 18, 2016
Have a look on Ebay:
pci network card
Make sure you know the difference between PCI and PCIE . Basically, they have a different fitting and aren't interchangeable.
There's a Youtube video which will show you the difference:
Identifying the differences between PCI and PCI Express Serial Port Cards
Gateway... | Answered on May 13, 2016
This computer does not ship with a graphics card. It contains a GPU, as all standard PC's do.
Gateway... | Answered on Feb 01, 2015
Hi! Actually there are a lot of different ways to do that... I will give you a list of software which easily recovers your password(s)... (There are othr ways using command prompt and/or safe mode e.t.c. ...) Anyway:
http://pcsupport.about.com/od/toolsofthetrade/tp/passrecovery.htm
The bestt of all is supposed to be this one:
http://pcsupport.about.com/od/toolsofthetrade/gr/ophcrack.htm
Good luck!!!
Gateway... | Answered on Mar 16, 2014
This is an snippet from the Gateway Website.
"In order to access the boot options on this portable computer, press the ESC or F10 key while the Gateway screen is displayed during the startup process. This opens a Boot menu with the option to start the computer to any of the available drives or to enter the BIOS Setup Utility. Use the UP ARROW and DOWN ARROW keys to select a menu option, and then press the ENTER key to start to the selected device.To "boot" (start) to a CD, DVD, or a floppy disk, the media must be in the drive when starting the computer."
Gateway... | Answered on Jan 27, 2014
It's either F1 or F2. However, once I had a Gateway which needed "Delete". You can try to put one finger on each button and press them successively. If everything goes right, you will enter BIOS and then you will have to enable lagacy usb support, change boot order so that you can boot from USB or CD (it depends...). Hope this helps!
Gateway... | Answered on Jan 26, 2014
This specific PC requires you to immediately press the "Delete" key at one-second intervals in order to access the BIOS.
Not the F1 or F2 key
Gateway... | Answered on Jul 10, 2013
There are a lot of ways on how you can optimize a computer. You can upgrade the hardware part of your computer which can boost up its performance or you can maintain the current the optimum capability of your computer by making sure that you have an anti-virus running on it and you have all drivers updated. I suggest you install RadarSync to automate driver updates. It's very important if you want it to run in its optimum level of performance.
David
Gateway... | Answered on Feb 19, 2013
es you can, In the Bios settings , select the advanced settings options and there you can increase the SHARED VGA memory..
Gateway... | Answered on Dec 29, 2012
I think you need only plug the modem into the router, then plug other devices into the router, or hook up through wifi..
If you want to reply, please click the Comment link.
Gateway... | Answered on Apr 06, 2018
Gateway SX2110G-UW318 Small Form Factor Desktop PC with AMD E1-1200 Logo
25 questions posted
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Gateway Computers & Internet
Most Popular Question
pc starts up said name welcome stays
  • Computers & Internet
