20 Most Recent
Canon Digital IXUS 860 IS - Digital camera - compact - 8.0 Mpix - optical zoom: 3.8 x - supported me Questions & Answers
I have all the softwares installed in my computer.
Find out where "Canon Camera Window" points to for its default pictures Folder and change that path or create a Folder in the location where it is pointing to ...
It seems to be directing the pictures to a non-existing Folder !
How do i take a self portrait photo - in simple terms please
Do you have a tripod ? If not a table or some suitable flat surface
that can serve as the tripod. Then set the timner to 10
seconds......press the button....and stand in position before the
camera. You may get the shots you are looking for. I do not know if you
can set the focus manually in this camera.
How can I buy a new lead to download to Macbook?
You might want to consider buying a card reader instead. They should be available at just about any department, electronics, or office-supply store.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo management program.
How can I delete individual images from my camera?
Press the review button to view your images. Navigate to the picture you wish to delete then press the delete button, it should look like a little rubbish bin. The camera will confirm the delete, so navigate to "yes" and hit [OK].
You should refer to your instruction manual for any further questions about using your camera and navigating its software.
Yahoo chat room
Although your manual des not say what the maximum time is your shutter can be open, try the M setting on the main dial.
Then you an chose time your shutter can be opened. On my powershot the maximum time is 15 seconds.
If that does not give you what you want, try the scene mode for fireworks, because then the shutter should be open several seconds too.
