20 Most Recent Packard Bell Pulse Smartpen 2 GB MP3 Player Questions & Answers
download firmware, easy !!
Packard Bell... | Answered on Aug 10, 2011
ys no other go u need to format
Packard Bell... | Answered on Jun 24, 2011
format and retry
If you have WS media player its automatic once you connect the speaker jack into the audio hole...dont forget to check if your speakers require power, plug them and increase the volume to an audible level.
If after all above has been done and no sound go to: Control Panel+ sound+ sound and click the drop down so you are able to change the option to windows default...click ok and apply. Then close and re open windows o play sound.
Packard Bell... | Answered on Apr 24, 2014
The issue quiet short, and I am not sure how to start on a solution, it would be fine if I may need more information so that I can give you a precise solution?
Thank you.
Packard Bell... | Answered on Sep 09, 2011
Google it, but spell it right "connect my microphone to my laptop".
One example http://www.musiconmypc.co.uk/art_connect_microphone_to_pc.php
Packard Bell... | Answered on Jul 09, 2011
be sure it is powered and on when you connect it ..and also the driver was installed into computer ...after that if it doesn't detect it ...run the add new hardware wizard from the control panel ..and select the already added feature..and see if it detects it ..If it do not came with a driver ..t means it is a plug and play device and it will be seen and installed auto ..
after that you should see it in the my computer folder as a drive ..(removable ) ..
al so be sure you confirm the connection with the p con the player if it asks ..(or take a look if it has a pc connection mode on menu or like a button feature)
Packard Bell... | Answered on Jan 04, 2011
repeatedly pressed on of switch and save battery switch, all in order now. Thank's
Packard Bell... | Answered on Sep 17, 2008
I am assuming the model you are using is similar or the same as the model I used once. That being the case, you need an external recording device and you simply use the headphone jack to connect the two. You should be able to use your computer and some simple recording software.
Packard Bell... | Answered on Jul 21, 2008
Packard Bell Pulse Smartpen  2 GB MP3 Player Logo
16 questions posted
Top Packard Bell Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Packard Bell Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Packard Bell Audio Players & Recorders
Most Popular Question
find firmware
  • Audio Players & Recorders
