1) Loaded with WM6.1, the last ROM released by i-mate before closing their doors, called v1.77 by them, the 9502 is able to handle both microSD and microSDHC cards, for what the maximum capacity would be, theoretically, 32GB. However, as I don't have such a big card to test, I can assure you that 16GB cards do work very well. If your phone is still loaded with WM6, I'm afraid you will be limited to 4GB cards. Nevertheless, only in case you happen to have the ROM lock code, which came printed in the original box and in some stickers inside it (otherwise, you won't be able to upgrade the ROM), feel free to download
this file to your PC and unzip it, Make sure either ActiveSync (for Windows XP) or Windows Mobile Device Center (for both Vista and 7) is running on your PC, connect your 9502 to your PC through the USB cable, run the unpacked EUM SFX executable file on your PC and follow the prompts. Don't disconnect your phone until you are told to.
2) I happen to have a pdf version of the 9502 user manual, which I have uploaded for you. You can download it from
this location.
3) The TV-out feature is buit-in. You just have to connect the custom cable which comes in the original package, containing a mini-USB connector in one end and 3 RCA plugs (video and stereo audio) on the other end to either a NTSC or PAL TV set (or AV system), and activate the TV-out feature, through either one of the system settings, or a shortcut in the hardware keyboard. You will be able to see documents and pictures, and watch videos stored on your phone directly on the big screen. I used this feature some times, but I found it pretty useful once, when I had to review a pdf file at a hotel room.
Well, please, let me know if you need additional informations.
Regards,
Carlos
