20 Most Recent
Lenovo ThinkCentre S51 8171 PC Desktop Questions & Answers
I have a lenovo thinkcentre S51 8171 KUU. It was
IF YOU JUST USE THE ONBOARD GRAPHIC,I THINK SOMETHINK IS WRONG WITH IT.
IF YOU DONT USE THE ONBOARD GRAPH.
CHANGE GRAPHIC CARD, THE S8171 SUPPORTS ATI x700 AND 700 pro, THEY HAVE 128 ,256 or 512 MB. THIS GRAPH._CARD IS A PCIEx16 and it will work WITH YOUR NORMAL POWERSUPPLY. NO EXTRA POWERCABLE FOR PCIEx16 NEEDED. AFTER INSTALLING, BOOT THE COMPUTER, GO F1 OR F2 TO THE BIOS. SET VIDEO SETUP TO PEG an STORE IT. NO OTHER CHANGES IN BIOS, NEVER GO TO IGD (THIS IS ONLY FOR ONBOARD GRAPH. )
NEVER GO TO COMBO.
OR MUCH MORE SIMPLE, USE AN OTHER MONITOR FIRST.
8/22/2011 3:15:13 PM •
Lenovo...
Answered
on Aug 22, 2011
Auto processing
The auto processing is the monitor trying to adjust to a particular resolution. To help you control display quality, please follow the steps given below:
-Open the 'Display Quality troubleshooter' by clicking the Start button, and then clicking 'Control Panel'.
-In the search box, type 'troubleshooter', and then click 'Troubleshooting'.
-In the left pane, click 'View all', and then click 'Display Quality'.
GuruAid.com
3/21/2016 7:05:57 AM •
Lenovo...
Answered
on Mar 21, 2016
I am having a Problem with my video card not letting me run an addition monitor off the vga output on the motherboard. I know it works because I can go to the bios and change it and it works but they
When using a PCI or PCI-E graphics card, it will disable your standard VGA output port because the up-dated graphics card and your factory VGA port require different display drivers. Usually, the drivers are conflicting and will make your system unstable and cause it to crash. In short, you can't use both at the same time. I have a Radeon HD 5450 graphics card installed on my PC and it too has disabled my standard VGA port. If you are trying to use more than one monitor, you have to install a graphics card that supports a multiple display output. The graphics card will either have 2 VGA ports, 2 DVI-D ports or 2 HDMI ports or even any combination of the 3. My card, for example, has 1 VGA, 1 DVI-D & 1 HDMI. I can run up to 3 monitors at a time via my graphics card, but I cannot run a 4th monitor from my factory VGA port. My graphics card uses ATI/AMD drivers while my VGA port requires the use of Nvidia drivers.
I hope that you find this useful.
4/5/2015 9:37:26 PM •
Lenovo...
Answered
on Apr 05, 2015
What does computer command "ipconf/release" do?
This command will flush the IP address from an active connection. The correct syntax is ipconfig /release *con* which will release all connections. If you just want to see if you can get a new address then use ipconfig /renew
11/3/2014 10:36:12 AM •
Lenovo...
Answered
on Nov 03, 2014
How do I get into think central
Hi, I just found this helpful user manual for ThinkCentre PC's in Adobe Reader (PDF) Format:
http://www.lenovo.com/shop/americas/content/user_guides/m58_m58p_ug_en.pdf
To access the ThinkVantage Tools, click "Start," then "All Programs," then "ThinkVantage Tools." To access the ThinkVantage Productivity Center, click "Start," then "All Programs," then "ThinkVantage Productivity Center."
The manual warns that these applications are available only on Lenovo ThinkCentre PC's with Windows 7, an internal hard drive, and Lenovo software pre-installed. I presume however, that you meet all of those criteria. I hope this is what you are looking for. Thank you.
10/27/2014 4:08:23 AM •
Lenovo...
Answered
on Oct 27, 2014
