20 Most Recent
Rheem 13AJN24A01 2.0 Ton 13 SEER Air Conditioner Questions & Answers
Reem air unit have to hold down reset button to keep running
that reset is for the high pressure switch. this means your compressor is getting to hot which is then increasing the pressure and tripping the switch because the fan isn't running. usually if a capacitor is bad you can give the motor a "kick start " and the blade will then start turning. use a long stick or screwdriver to spin the blade but then you will know you need a cap. that switch is protecting your compressor, don't hold it down to keep it running. If you need further help, reach me via phone at
https://www.6ya.com/expert/thomas_092728000e6acb79
No cooling of house/no fan-only click when setting temperture
check your air handler overflow pan and check to see if it is full of water. If so, you need to unclog the normal drain and remove the water in the overflow pan, once level is low enough the float switch will reset and control power will start unit up again.
Rcba 4882g how much is it to replace the central AC condensing unit
This will be dependent on the capacity (tonnage or BTU/Hr) of the condenser, its location and how much refrigerant will be needed to added / replaced - plus the labor to do it. A typical 2 - 3 ton residential system (air handler / condenser - no duct work, etc.) can run $2k and up.
Burner dont stay lit long enough to put out heat
If this is a reasonabley new style furnace it's because your flame sensor, they get tarnished and you have to follow the Orange wire on the left side of the burners that leads to the screw (1/4" hex) that you have to remove before you can remove the sensor. Once you do you will need to clean the sensor (it's just a rod bent to a right angle) use some fine grain sand paper, or Emory cloth, and put it all back together, and there you go.
