20 Most Recent
Sony VAIO VGN-NS130E/S Notebook Questions & Answers
How to use the web
By default, this button causes your default web browser to open. It will open a new home page on the screen.
12/24/2010 6:11:52 PM •
Sony VAIO...
Answered
on Dec 24, 2010
VGN
vaio computers came with vaio recovery partition to format the harddrive without using recovery cds.
- restart the computer
- when you see the VAIO logo, press and hold F10 for 5 to 7secs until you see loading files or edit boot options
- if you see edit boot options, press enter
- it will load the vaio recovery center
- choose restore c: drive from vaio recovery center
- follow on-screen instructions
- process may take up to 45mins or 1 hour to complete the recovery with random restarts
you may also take a look at this link:
how to format vaio computers
4/10/2010 4:49:42 PM •
Sony VAIO...
Answered
on Apr 10, 2010
I want to format my laptop what do i need to do?
boot up using a bootable CD (the Windows CD for example) and pick fresh install. It will ask if you want to format your hard drive (and lose everything - Windows will not longer be there or any of your files).
3/1/2010 8:36:31 PM •
Sony VAIO...
Answered
on Mar 01, 2010
Code error 0xc0000185
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop.
Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185)
This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information.
Causes of Error Code 0xc0000185:-
1. Suffer a cable attachment joining to your system and the hard drive.
2. Defective or missing boot files.
3. The disk drive gets damaged.
4. Wrong disk drive.
Solutions of Error Code 0xc0000185:-
1: Do sure that Wire is Correctly Connected [Only for PC]
2: Automated Repair
3: Check Hard Disk for Errors
4: Repair your System to Fix Error 0xc0000185
Full Solution -
9/14/2022 11:53:07 AM •
Sony VAIO...
Answered
on Sep 14, 2022
Lost video on svt131a11l
Try to:Open Computer by clicking the Start button and then clicking Computer.Navigate to the folder or drive that used to contain the video file, right click it and then click Restore previous versions. https://8ballpool.onl/ https://googlehangouts.ooo/ https://omegle.onl/
9/30/2018 12:52:58 AM •
Sony VAIO...
Answered
on Sep 30, 2018
System has slowed down and freezes regularly. it
A lot of anti viruses cant find or get rid of pups, which are potentially unwanted programs that sneak onto your computer, go to mybleepingcomputer.com and download and run adwcleaner, its free and gets the boogy men out.
1/22/2018 2:02:26 AM •
Sony VAIO...
Answered
on Jan 22, 2018
My laptop has limited internet access. I've called
Hello -
Depending upon where (in your home?) you use your Sony Vaio laptop (via WiFi?) you may need a WiFi booster or extender. Or, you may find that moving your WiFi router to another location in your home will improve your connection without diminishing the connections for other laptops used in your home.
Perhaps the information here will prove instructive:
https://www.repeaterstore.com/pages/wifi-booster-repeater-extender-differences
Note: If the router needs to be moved in your home, you will probably need a technician for your Internet provider to come to your home to relocate it and connect it properly.
12/28/2017 11:26:53 PM •
Sony VAIO...
Answered
on Dec 28, 2017
Apple mobile device usb drivers has malfunctioned and exceed the power limits of its hub port.
Ewwwwwww... no fun.
You should try a
"POWERED"
4 Port USB 3.0 Hub
It's important that it's a
"POWERED HUB" because you need
the HUB to supply it's
OWN power and not depend on your Apple E to provide power to your connected USB devices!
The good news is they don't cost much:
$8 on eBay
Auction: 202096902632
Note that they include the power supply! Many other HUBS don't.
Your HUB is even LESS if you pick on the USB 2.0. Version,
AND YES, each HUB MUST have it's own power supply and that's just what YOU need.
The ONE thing I didn't like about this HUB is the LED lights that are provided for each port! They are TOO bright so I opened it up and plucked all but one LED out. I also bought the 8 and 10 Port HUB versions and 'fixed' them too.
I also didn't need the switches to confuse things (accidentally turn one or more ports OFF)... so my trusty hot glue gun fixed that! All are constant ON now.
Anthony
Black 4 Port USB 3 0 Hub On Off Switches AC Power Adapter Cable For PC...
12/2/2017 5:45:59 AM •
Sony VAIO...
Answered
on Dec 02, 2017
1My Sony VGN-UX230P has many
Gotcha... it MAY be a internal ribbon cable to your screen is loose (or not seated 100%) OR sometimes a cable one conductor inside the cable breaks and acts like a switch ~ providing a OK display sometimes ~ or not.
A PC repair shop will take a quick look for you for X-Bux and IF it is a loose connector/ribbon cable they MAY be able to fix it for you on the spot... A decent camera repair shop may be a answer for you too? They are very familiar with tiny screws and display repairs. Be careful though and don't spend too much...
I would not recommend you open it yourself because sometimes things go "boing" and tiny things go flying.
Anthony
12/2/2017 1:49:22 AM •
Sony VAIO...
Answered
on Dec 02, 2017
