20 Most Recent Canon Powershot SX110 IS Digital Camera 9.0MP Questions & Answers
This camera is ancient by today's standards, at least 8 years old.
Your focus problem is that the back display is very low resolution, so it will never show a sharp image. 9MP should give a decent image when you view it on a computer. If not, you probably need to part with the camera. it is not worth much these days anyway.
Canon Powershot... | Answered on May 01, 2017
The size is going to be based off of clarity per pixel, the higher the MP the more pixels in turn the larger (but more clear) the picture.The best way to keep the clarity would be to resize on your computer, if you have windows, open the picture(s) with PaintStart Menu -> Programs -> Accessories -> Paint
Then after you've opened the picture, do the followingWindows XP -> click "Image" then "Stretch/Skew"Vista/Windows7 -> Click "Resize"Make sure you keep aspect ratio percentages locked or you'll come out looking like a circus image.
Canon Powershot... | Answered on Mar 16, 2015
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Canon Powershot... | Answered on Nov 20, 2014
Here are some troubleshooting steps for lens errors:
Canon Powershot... | Answered on Nov 07, 2014
Asoftech photo recovery program can recover photos from formatted, lost or damaged memory card, you can follow this user guide
memory card photo recovery
Canon Powershot... | Answered on Jan 21, 2014
You can use some camera recovery software to get back pictures erased from camera. You can refer to this tutorial that helped me before
Recover pictures from camera
You can view this camera picture recovery tutorial that helped me before
Canon Powershot... | Answered on Feb 17, 2013
Replace the clock battery following the instructions beginning on page 194 of this manual.
Canon Powershot... | Answered on Jan 04, 2013
To delete an individual photo, while playing back the photo press the trashcan button located just above the control dial. To delete all photos on a memory card, format the card by using the Format command in the Setup menu.
If you need a manual you may download a copy here.
Canon Powershot... | Answered on Dec 02, 2012
First see if the camera will work without the memory card installed. Then format the internal memory using the camera's setting as described in the manual.
Then turn OFF the camera and insert the sd card. Turn on and reformat the card too.
Make sure you have NEW batteries or sometimes things go flakey.
Canon Powershot... | Answered on Sep 22, 2012
Format the memory card.
Canon Powershot... | Answered on Apr 30, 2012
it is possible that the original "Save Folder" has been deleted or name changed. Go to options and create a new folder to save your photos to. Hope this can help. UAW 974
Canon Powershot... | Answered on Apr 18, 2012
You can remove them in a photo editing program.
Canon Powershot... | Answered on Sep 16, 2011
There are TWO screws on the right side, one is hiding under the cover for the USB connection!
Now you should be able to pop it off and... I'm guessing here... replace your cracked LCD screen. Good luck, hope this helps.
Thomas Drayton
Owner www.darntoothysam.com
Affordable Digital Camera Repair
Canon Powershot... | Answered on Aug 04, 2011
http://sites.google.com/site/digitalcamerarepair/sd600
here you have a step by step guide about changing the lcd on a few models of canon SD ..the procedure will be the same ...but in your case be sure there are no screws left ...if it do not seam to be able to separate ...or ...see if the wrist strap mount is not screw-able ..It also can have another kinda system and be snapped in ...or slide ..After that the removing and the plugging of the ribbon is the same ...pay attention cause the plug should have a lock mechanism
Canon Powershot... | Answered on Jul 25, 2011
Canon Powershot SX110 IS  Digital Camera 9.0MP Logo
111 questions posted
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
PowerShot Canon
  • PowerShot Canon
Most Popular Question
camera erased all pictures sd
  • Cameras
