20 Most Recent BenQ DC C740i Digital Camera Questions & Answers
0answers
0answers
My camera not come pic in display
Potential symptoms may also include purple scratchy lines showing up on the LCD monitor and the camera's pictures. Other reported symptoms may be extremely distorted images (one reader likened them to the movie "Grudge"). Or blank or black pictures or black videos with good sound being recorded on the camera's flash card. You may suspect that the camera's shutter is not opening, but this is not the case. Note that the camera's menu functions should show up without any problem.A large batch of potentially faulty CCD image sensors (from another vendor who shall remain nameless) were installed on a large number of Canon cameras over the space of a few years. The sensors may go bad prematurely with time, especially if you live in humid areas. A big thumbs up to Canon in that they recognized this problem, and are willing to fix your camera for free if it is experiencing CCD problem symptoms, especially for the free shipping and handling both ways :-). Under the recall advisory this is regardless of the cameras warranty status!If you fell with expertise in this, check the follow video....Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.Thank you for using FixYa, have a nice day.
1/31/2012 10:32:02 PM • BenQ DC C740i... • Answered on Jan 31, 2012
Power cenot open
power cenot open
8/10/2011 7:09:36 AM • BenQ DC C740i... • Answered on Aug 10, 2011
tip
Memory card locked
This is a tip explaining the error, "Memory card locked". We will also give you the resolution for this error. This error, or rather message, is usually the result of the following situations.
Situation 1:
Well, this is usually the problem, on the memory card, there is a little switch on the left side, which can switch between "Lock" or "Unlock".
If you get the display, memory card locked, remove the card from your camera, or USB adapter and have a look at the switch, if it is switched to locked, move the lever top the other side and place it back. This should solve your problem, if not, lets have a look at situation 2.
Situation 2:
Open the card slot of your camera and have a look inside with a bright light/ torch. You should see a little metal tab or switch inside the card slot. This is the write protection switch.
With time and repeated use , the switch will start to bend slightly until it will no longer depress when a unlocked card is inserted.
With a toothpick or needle , slightly and very gently push this tab up a little bit. (some camera's will require you to pull the tab down), This will allow the switch to operate once again and should solve your problem.
I really hope this can steer you in the right direction. Please rate accordingly.
Kind regards
Andrea
Card error. can't do anything
  1. Try using a new, clean, pencil eraser, to gently rub the contacts on your memory card making certain no to leave any rubber shavings on the card.
  2. Un-install and re-install the card 10 -20 times (this will rub the inside contacts clean an re-align the card)
  3. If that doesn't work and you absolutely have to have the photos on that Memory Card, you can purchase any one of many Memory Card Photo Recovery Programs, available by searching recover photos from memory card.  Here is One Example (no necessarily a recommendation as I have never used this or any photo recovery software)
  4. Finally, from the camera's menu, Select <Format>, you will lose any pictures you may have on the card but you should be able to rectify the problem
Thank You For Choosing FixYa~!
3/21/2011 4:27:20 PM • BenQ DC C740i... • Answered on Mar 21, 2011
I hold start button pressed but the camera does
unplug battery for a few min. then plug back in.
2/22/2011 2:47:28 PM • BenQ DC C740i... • Answered on Feb 22, 2011
Cannot take a picture..warning card
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
8/5/2010 4:34:30 PM • BenQ DC C740i... • Answered on Aug 05, 2010
Lost cd-rom
TRY GOOGLING SOFTWARE FOR BenQ DC C740i Digital Camera.
YOU CAN OFTEN FIND THINGS BY THIS METHOD
ALSO PDF USER MANUALS.
MAY TAKE A BIT OF SEARCHING
2/15/2010 5:26:00 PM • BenQ DC C740i... • Answered on Feb 15, 2010
0answers
Lcd problem
Be the first to answer 1/25/2010 5:28:44 AM • BenQ DC C740i... • Posted on Jan 25, 2010Be the first to answer
Lcd on my benq digital camera DC C740i was cracked
Take it to Black's or Henry's. They can replace the cracked part
1/2/2010 4:06:44 AM • BenQ DC C740i... • Answered on Jan 02, 2010
I'm using benq dc c740i recently i accidentally dropped my camera to floor it stuck and the lens can't go inside when i restart my camera it come out a beep sound and it suddenly shutdown
Sounds like you broke it. I doubt it can be economically repaired. Get a new one, and don't drop it.
7/15/2016 12:41:22 AM • BenQ Cameras • Answered on Jul 15, 2016
Benq camera . Zoom out of the camera no longer operate and emits sound as if there is something aperture of the lens ..... Please reply disadvantage , and how to fix it
Hi Beshoui, I believe your zoom lens is not extending when you power on. In most cases like this, there is likely a foreign body (sand) or similar objects lodged between the lens tubes or the camera has been subjected to a knock (dropped, bumped against a solid surface) that caused the lens tube to miss-align. All you need to do is: 1. as you switch on the camera, give a little knock/ tapping with your fingers around the lens. 2. if that fails, apply a little pressure to the sides of the lens ring while powering on your camera. Lets hope that will help to dislodge the foreign body or the lens tube miss-alignment.
2/8/2016 11:58:47 PM • BenQ Cameras • Answered on Feb 08, 2016
BenQ DC C740i Digital Camera Logo
Popular Tags
23 questions posted
Top BenQ Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Eric
ADMIN Eric
Tony Parsons
Tony Parsons
Are you a BenQ Camera Expert? Answer questions, earn points and help others
View Most Popular
BenQ Cameras
  • BenQ Cameras
Most Popular Question
lost cd rom
  • Cameras
