20 Most Recent Velbon Sherpa DV7000 Tripod Questions & Answers
Hi I need a locking clip for one of the Velbon Tripod legs any suggestions?
cheers
Wayne
Velbon Sherpa... | Answered on Aug 05, 2013
The XL attahes with a 1/4 or 3/8" camera screw or via an Arca compatible QR. If it is not tight on your tripod the problem is probably in the tripod head.
Velbon Sherpa... | Answered on Sep 04, 2011
Hi, Folks!
I just cracked the Velbon's DV-700 tripod head mounting screw, that is on the top of the extending column. I need a replacement for this. Screw is on the top of the column.
Any suggestions?
Thank's in advance
Velbon Sherpa... | Answered on Jul 02, 2011
Try www.TripodQuickRelease.com for that part. There is listed the widest selection of quick releases and support more brands than any other web site I've seen.
Velbon Sherpa... | Answered on Sep 23, 2010
I cannot tell you esactly, but it seems to be more of an oil or grease than a liquid.
Velbon Sherpa... | Answered on Jun 25, 2010
That sticky stuff should be grease for the roller bearing that rolled away on you. Dont chance it Purchase a new one for you cameras sake
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Velbon Sherpa... | Answered on Jan 01, 2008
I wouldnt chance it but get a good heavy one with metal locks and such
Tripod heads have standard thread sizes, 1/4" or 3/8" so you will have to check size. You can get an adapter if its different.
Same brand should be same thread so you should be ok to change.
You just have to try it to see.
Velbon... | Answered on Apr 07, 2019
I presume this is a tripod, although you have not stated. On good quality tripods, the head attached to the centre column with a screw thread, either 1/4" or 3/8". Grasp the centre column firmly, and rotate the existing head anti-clockwise, first checking to ensure there are no grub screws restricting its movement. When you have removed it, attach the replacement.
Velbon... | Answered on Oct 15, 2017
Is a manual or instruction leaflet really necessary ? Tripods are actually amazingly simple to use. You spread the three legs (three legs - 'tri'-pod) and place them firmly on level ground. Then you attach the camera, camcorder, spotting scope or whatever to the top, and use the equipment as desired.
Velbon... | Answered on Sep 13, 2017
Unless you have added an adjustable head to this monopod (in which case you need the QR plate appropriate to that head), it appears to feature only a standard 1/4" thread screw, which has in and of itself no QR capabilities.
Please pass this info to your friend Anonymous.
Velbon... | Answered on Feb 20, 2017
Velbon Sherpa DV7000 Tripod Logo
12 questions posted
Top Velbon Photography Experts
Bill Eager
viking_nm
viking_nm
Level 1 Expert
txslim55
txslim55
Are you a Velbon Photography Expert? Answer questions, earn points and help others
View Most Popular
Velbon Photography
  • Velbon Photography
Most Popular Question
canon 400d ef 100 400 zoom lens
  • Photography
