20 Most Recent Lexmark X5070 ALL-IN-ONE InkJet Printer Questions & Answers
Lexmark Printer Problems ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/13953
My printer Z12 Color Jetprinter is printing triple letters (printing on top of each other). ..... I have a Lexmark All-In-One X5150---It says "color cartridge missing" butthe ... We removed the ink cartridge and looked on the back of it and realised that .....to the right side of the computer ..if someone can tell me whats wrong or how ...
Lexmark Reset ink cartridge ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/35235
Jun 3, 2009 - Does any one know how I can reset my ink levels in the Lexmark All inone ... The best way to reset any lexmark inkjet is to buy a real printer. ... fool the empty ink cartridge signal on the Lexmark but putting a piece of "that never ..... So sure the printer prints but is it just using up the color cartridge to make the ...
[PDF]5000 Series User's Guide - Lexmark
Lexmark X5070... | Answered on Sep 20, 2018
Test by sending fax to 1300 688 999. Results will be faxed back. Automated service. Cost of local call.
Ring your fax from your mobile when you are next to it and hear it ring and answer.
ADSL filters in place???
Lexmark X5070... | Answered on Feb 18, 2016
Are you faxing from the computer or from the control panel directly from the all-in-one? Do you have an answering machine on the same phone line as you fax? which could be interfering (picking up) before the fax machine can pick-up (called the hand-shake, as in when you hear all the funny noises and tones that go back and forth between two machines) In any even, read your manual to make sure it is set up to Tx (transmit) and Rx (receive) faxes; that feature could be off by default http://www.bhphotovideo.com/lit_files/695.pdf
Lexmark X5070... | Answered on Nov 22, 2013
Sandra- some ink jet printer manufacturers are proprietary and use ink cartridges manufactured with "timers" built into them- making it almost impossible for the end-user to re-use them.
You mentioned that you refilled the cartridges; and without knowing what you actually mean by that, I will have to ask you; did you refill the cartridges yourself, or did you send them out to a third-party vendor?
Or perhaps, you are using a generic brand?
All of which can be problematic, if your particular model printer (not all) uses ink expiration technology on their ink cartridges or proprietary technology.
What does this mean? Ink expiration is a built-in date in which certain ink cartridges will stop working; even when there is still ink in them. Manufacturers like HP, claim that it uses such technology to protect the printing systems print-head and ink supply (which are two separate and distinct physical properties on certain printers).
Which now begs the question, does your printer have print-heads that are separate from the ink cartridges?
BTW, ink cartridge nozzles can dry out and block the flow of ink from its reservoir. You can try to manually clean the printer cartridges by using a q-tip swab dipped in rubbing alcohol until it is completely clean.
On a final note, another possibility in the troubleshooting process, reset the ink cartridges chip to full.
1) You can buy a universal ink cartridge resetting tool online or at a local computer or electronic store.
2.) When you do, remove the ink cartridges out of their holding carriages.
3.) Line up the device pins on the resetting tool and the chip on the cartridge. Press the pins and the chip together until they connect.
4.) Keep the pins and the chip connected until the device's LED light turns green (usually takes 10 seconds)- the chip on the ink cartridge will have reset.
5.) Reinsert the ink cartridge into the printer's ink carraige and print a test page. The printer should recognize the ink cartridge.
If all else fails and as a last resort, you will have to buy a brand new proprietary ink cartridge
Please keep me posted.
Lexmark X5070... | Answered on Nov 17, 2013
Dont buy anymore Lexmarks!
Lexmark X5070... | Answered on Sep 04, 2013
Connect the printer to computer. Will install automatically.
Lexmark X5070... | Answered on Aug 12, 2012
Actually, it does not matter what mode your printer is on when printing from your computer. Whenever your printer detects a print job sent to it, the printer will automatically acknowledge the signal and print the file - no matter if it's on Copy, Scan or Fax Mode.
Lexmark X5070... | Answered on Feb 25, 2012
You need to unplug the power from the printer and then plug it back in and see if this does the trick
Lexmark X5070... | Answered on Jan 17, 2012
Try to plug the printer into a different known working power outlet in the wall. Bypass any power surge devices or power strips - these tend to draw away power from the printer.
Lexmark X5070... | Answered on Dec 28, 2011
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer > reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Try to reinstall the OCR scan software by inserting the Lexmark installation disc that came with your printer into the computer hard drive. If you have a firewall enabled, make sure to allow all Lexmark scan and print processes in the program rules or permission.
If you lost the disc, please contact Lexmark Technical Support Center to request one for free.
Try to re-seat the cartridges into the printer. Remove both cartrdiges > . pull out the power supply (black box where the power cord is plugged in at the back of the printer) and put it back after 30 seconds > firmly re-insert the cartridges. Let it print the alignment page.
If the display screen shows "low black ink" again, then try to replace the black cartridge. The printer requires all cartridges to have sufficient ink in them to continue printing. Try to replace your black ink with a new one, preferably a genuine cartridge.
Should you still need assistance, please leave a comment to my response and I'll get back to you.
Lexmark X5070... | Answered on Oct 14, 2011
We apologize for the inconvenience. Please follow the steps below to identify and fix the problem:
  1. Open the printer cover to access the cartridge area. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  2. Remove both cartridges from the printer.
  3. Check the cartridge area and make sure encoder strip is not loose. The encoder strip is transparent strip located behind the cartridge carrier along with the carrier belt.
  4. If encoder strip is properly seated in the printer, close the printer cover.
  5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  6. When the printer turns on, re-insert one cartridge first. Close the printer cover and check for any errors. The carrier jam could be due to one of the cartridges.
  7. If no error appears, re-insert the other cartridge.
  8. Replace whichever cartridge is causing the error to appear.
  9. If no error appears, try to print again to verify that the carrier jam issue is fixed.
We hope this information has been helpful.
Lexmark X5070... | Answered on Oct 12, 2011
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Lexmark X5070... | Answered on Sep 04, 2011
Lexmark X5070 ALL-IN-ONE InkJet Printer Logo
108 questions posted
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
X Lexmark
  • X Lexmark
Most Popular Question
lexmark x5070 more 3 years
  • Office Equipment & Supplies
