20 Most Recent
Motorola att cl4939 corded digital answering system with large tilt display Questions & Answers
How do I disable the voicemail on my Motorola CD4 landline?
Hi Sherry,To disable the voicemail on your Motorola CD4 landline, you will need to contact your landline service provider and request that they disable the voicemail feature on your account.The process of disabling voicemail may vary depending on the service provider, but typically, you can do this by calling their customer service hotline or by logging in to your account online.Once you are connected with a customer service representative, explain that you want to disable the voicemail feature on your account. They may ask for verification of your account information and may need to make changes on their end to complete the process.It's also worth noting that disabling voicemail means that the callers will no longer be able to leave you a message when you are unavailable. So, make sure you consider this before making a final decision to disable voicemail.
Motorola CD4 cordless phone gives fast busy after a voicemail is left, and that busy gets saved with the voicemail. How can I stop this?
The fast busy signal that you are hearing after a voicemail is left on your Motorola CD4 cordless phone is most likely due to a problem with your voicemail service or your phone line. Here are a few things that you can try to resolve the issue:
- Contact your phone service provider: If the fast busy signal is being caused by a problem with your phone line or voicemail service, your phone service provider should be able to help you resolve the issue.
- Reset your phone: Try resetting your Motorola CD4 cordless phone to its default settings. You can do this by unplugging the phone's base unit and removing the batteries from the handset. Wait for a few minutes and then reconnect the base unit and reinstall the batteries.
- Check your voicemail settings: Make sure that your voicemail settings are configured correctly. Check your phone's user manual to see how to access and adjust your voicemail settings.
- Try a different phone: If the problem persists, try using a different phone on the same phone line. If the different phone works properly, the issue is most likely with your Motorola CD4 cordless phone.
Motorola 02digital cordless telephone with answering machine is not ringing when getting external calls. I tried increasing the volume but it doesn't work
8.Handset settings8.1To set the handset ringtoneYou can set different ringtones for external calls and internal calls.Select from 20 handset ringtones.You will hear a sample ring as you scroll to each ringtone.Press Menu, scroll1.2.Set Handsetis highlighted. Press Select.Ringtoneis highlighted. Press Select.3.UD4. ScrollorUD5. Scrollorn6. Pressto return to standby mode.8.2To set the handset ringer volumeThe handset has 5 ringer volume settings plus Off.If the volume is set to Off,Press Menu, scroll1.2.Set Handsetis highlighted. Press Select.DRinger Volume3. ScrolltoUD4. Scrollorn5. Pressto return to standby mode.NotesWhen the phone is ringing, you may presscall.When the handset is in standby mode press and holdpress and hold*8.3To set the receiver volumeThis sets the standard volume level for the handset earpiece or hands-free.There are 8 levels to choose from.Press Menu, scroll1.2.Set Handsetis highlighted. Press Select.DReceiver Vol.3. ScrolltoUD4. Scrollorn5. Pressto return to standby mode.Handset settingsDSettingsand press Select.totoExternal Callorto the ringtone that you want and press Select.icon is displayed
I want to download music from my computer to my android
In my V-750, I got a Micro SD, formatted it in the cell, put it in an SD carrier, and moved it to my PC, then copied my MP-3 files into the My Music subdirectory on the micro SD.
When I put it back into my cell, it was detected and the music files came up in my directory.
Carl
Cordless Motorola l601m says out of range, power up , worked good yesterday what is wrong
Well I guess this is a cell phone..When you shut it off then back on it connects to the closest tower..That's why it works good.. As you travel it switches towers... sometimes it doesn't return.. There are numbers you can call on your phone to update the towers as they are adding more and more..You can also put you phone on airplane mode for a sec or two.. Then turn it back off...That will reset you to the closest tower without having to turn your phone off...Hope this helps
