20 Most Recent
Gateway FX7026 PC Desktop Questions & Answers
Gateway fx7024 won't boot. Power lights come on
Hi Bradford.
Pls follow the below steps and let us know the result.
1. Remove the power and press and hold the power button for 1 min.
2. Remove all wire and clean them. Reconnect them.
3. Now to boot the system.
4. If it didnt worked then you have to open the CPU and clear the RAM ( Please read the mannual book. Incase if you are not comfortable with this kindly check any hardware mechanic)
Let us know incase for any progress.
Keep using FixYa.
Subhankar Ghoh
Fx 7026 added memory slow boot
add more ram is the best way of speeding up a computer
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules
are all ram modules working if you click start right click on computer select properties you will see installed ram and usable ramyou might have to many programs running at the same time putting to much strain on the CPU
try uninstalling a few unnecessary programs
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now
click start tick in both boxes this will schedule to on restart
do not have any input while chkdsk utility is in progress any might further damage your computer
scroll to the bottom toolbar bottom of screen right click you can select task manager applications also processes you will see whats running on your computer and ticking over you might have a virus
if you see something running that you does not need to be running select end now then you might you might uninstall that particular program
and some unnecessary programs this should speed up your computer
you should also check leads from motherboard to hard drive for secure dust free connections
if you need more help with this post a reply
hope this helps you
First of all, I have a Gateway Model FX7026
check if the cpu fan its working fine, maybe is damaged o dirty, you clean up with an air compress can
if still doesnt works you can try to replace the fan and see if it works
Gateway desktop fx 7026 memory
the specs i read says 8 gig is the max. here is what it says for RAM
RAM
- Installed Size 4.0 GB / 8.0 GB (max)
- Technology DDR2 SDRAM
- Memory Speed 667.0 MHz
- Form Factor DIMM 240-pin
- Features Dual channel memory architecture
- Configuration Features 2 x 2 GB
check to make sure you have added the right type of memory. also look at your user manual. it should tell you where and how to place the added sticks. sometimes they have to be added in pairs or have to be in specific slots. also if you dont have the manual it is on the gateway site. you should type in your model and serial number and get all the info you need.
Gateway fx7026.....beeps three times on startup
Test your PSU or replace it
One bad lead can cause a computer to continue on a cycle or to shutdown
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
I was using the computer
hi your cpu fan might be loose or your RAM open pc and make sure cpu fan is secure if its loose a little tighen it or your RAM might have popped out it can get very hot around RAM and sometimes it pops out ...hope this helps be carefull...bonnell
Drifting cursor
Hello, Honest.
With not much to go on here, it sounds like you either have a mouse problem or malware or spyware.
Is it possible that you are pressing the mouse kind of hard ? Do you have another mouse to replace ?
It also can be malware or spyware. Download, install and run these free programs, one at a time:
http://www.malwarebytes.com and
http://www.spybot.comHope this helps.
Graphics card or motherboard problems...
You've run the antivirus. Next, try to run malware & spyware programs. THen, run a good registry cleaner. This will aim the right things with the right things. If you made ANY changes to hardware, software, programs or data, there will be changes in your registry.
SCREEN FREEZE-CHECKER BOX
reboot your computer and during starting type f 8 keys then start in vga enable mood then setup vga 1024 .
How do Imanually ejecting a disc from a gateway
There should be a small round hole on the door near the eject button.
Using a straightened heavy paper-clip, insert straight into the hole.
There is a lever inside that you will feel, press in until the door comes partly open.
Then you can pull the door to access the disk.
