20 Most Recent
HP Compaq Presario SR2038X PC Desktop Questions & Answers
Computer won't do anything, keyboard does not light up, screen is blank
So there is not so much as a BIOS message on screen? Any beeps?If there is no life at all, you have a CPU/motherboard failure. This may be direct or indirect (e.g. no power to MoBo). Check your connections.Otherwise, your boot device may not be operating. This is usually a dead or disconnected HDD. Check that it is plugged in. Does it get warm? Can you feel any vibrations from it? It should spin even if your cpu is dead but MoBo is alive.
10/27/2012 3:12:22 PM •
HP Compaq...
Answered
on Oct 27, 2012
Monitor keeps going to sleep
for windows 7
in the control panel
go to hardware & sound
go to power options
go to balanced or power saver
change plan setting
you change settings to what you want
if you have windows xp send me a comment
12/1/2011 2:35:31 AM •
HP Compaq...
Answered
on Dec 01, 2011
Lately when I boot my
Your Cmos battery is flat. Replace it. Look at www.insidemylaptop.com for a pictorial view.
Hope this helps.
2/14/2011 10:49:31 PM •
HP Compaq...
Answered
on Feb 14, 2011
Compac presario CQ62
Hello
Most laptop or PCs, has a combination keyboard pressing keys, that invoque the restore routine.
usually F11 or F10.
others has DVD, check and see what you have of these two.
in the first one, you recover from a disk partition the whole OS.
Bios update fore presario 8000
Its all about go to HP page, and bios updates, the instructions are there too!
but be aware you have to be more specific on model, and BIOS dates.
Compaq presario sr5350f pc and i keep gtting windows is shutting down everytime i click the help button
You may have a virus, malware, adware, a browser hijacker, or pups (potentially unwanted programs). A. If your computer will boot and you can operate it ok... Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found. B. If your computer won\'t boot, or can\'t operate properly after boot... Tap F8 when you are booting, select "Safe Mode With Networking". Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found. C. If this process finds malware, to keep stuff like that from coming back, I recommend you get the paid version of Malwarebytes.Good luckG
Hp 6830s
If the fan making a smooth spin, but the noise is too loud, then it means the fan is trying to dissipate the heat. Probably the air inlet and or the air outlet (also the fan itself) is dirty (or clogged) and you need to clean it up using a canned air.
You may need to open the case/body if the dust become a dust ball (and you need a tweezer and qtip to pickup the dust ball and clean up the fan blades).
Increase virtual memory
no proberly not,you should never do so.i understand you wan't to add moore memory (RAM)windows 32x can only handle max 4 GB.windows 64x 8-12 GB.invest in some new memory (RAM) that's best.
