Numatic HVR200P Bagged Canister Vacuum
Take a brief Survey Take a brief Survey   Add to My Products Add
Problems with Numatic HVR200P Bagged Canister Vacuum?
Troubleshooting and Support
Solved Problems for Numatic HVR200P Bagged Canister Vacuum RSS Feed Post a New Problem
i cant get the roller back in place
please help i have a kirby that i cant get the roller back on after taking off and putting on a new belt! it is driving...
1 Solution
Kirby G6 Shampooer
I need instructions as to how to put the shampooer together and if there is a way to make it compact enough to do...
1 Solution
self propelled wind tunnel vacum will...
Why doesn't my self propelled vacum not move when handle is released,when both belts are intact and roller brush moves...
1 Solution
Porter Cable Roofing nailer rn175a
My gun drive rod is not retracting, it fires fine but will not retract.
1 Solution
Power Consumption Refridgerators
Hi thereI am in the process of buying a generator for power losses (I live in a rural area) to ensure the Fridge and...
1 Solution
manual got wet, need new one
This is not a real problem for you, but I really need a new manual for my steamer.  Its a hand held household,...
1 Solution
My steamvac f5870-900 trigger mechanism...
I had a rattle in the handle portion of the steam vac so I took the handle apart (by reversing the assembly guide) and a...
1 Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Feature
DesignCanister
Dirt CaptureBag
Tank / Bag Capacity2.38 Gallons
Motor
Consumed Power1000 Watt
Voltage220 - 240 V AC
Amperage4.3 Amp.
Suction
Airflow95.35 cfm
Tools
Cleaning Path11.81 in.
Convenience
FeaturesCord Rewind
Cord reach104.33 ft.
Hose Reach8.2 ft.
ColorYellow · Red · Blue · Green
Special Features
Sound Level54 dB(A)
Weight
Weight14.55 lb.
Warranty
Warranty2 Years Parts and Labor
Sponsored Links
Loading problems.
Top Vacuum Experts
Nzero
2 solutions
Computer Hardware, Large Appliances, Small Appliances...
Ask Me
Guru
chrispur
42 solutions
Flat Panel Televisions, Standard Televisions...
Ask Me
Guru
bbtoast
1 solutions
TV and Video, Cameras and Photography...
Ask Me
Guru
Repair Service
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
