20 Most Recent
Goodman CLT48AER48 Air Conditioner Questions & Answers
My unit outside is working
Is the condenser coils clean..... If not take a hose and wash the condenser coils But make sure you shut the Main power off to it. Has the unit been charged with Freon lately??? If so they may have gotten it overcharged which will cause High head pressure and make the compressor noisy..... Or is it out of level and not setting on a stable surface. causing a vibration noise. You can put rubber pads under the AC if it is a vibration noise...... Also the Compressor may be going out..... It is hard to tell with out hearing it first hand....Hope this helps If you can't get it to quite down I would setup a Service Call to have them Service the AC and that you are having a loud noise coming from the unit....
5/5/2011 3:31:28 AM •
Goodman...
Answered
on May 05, 2011
Central AC comes on but won't stay on. Could it
this is possible only if there is a Low Pressure Switch on the unit. Most residential units do not have those but it is possible. I'd look else where, such as thermostat for starters.
9/15/2010 2:42:19 AM •
Goodman...
Answered
on Sep 15, 2010
Compressor making buzzing sound wont start
Check voltage at the load side of the contactor. Check continuity of the compressor windings. Disconnect the power first. Connect one lead of the ohmmeter to Common, then connect the other to the Run winding and read meter, then connect to the Start winding and read meter. Neither should indicate an open leg.
5/11/2010 2:19:24 PM •
Goodman...
Answered
on May 11, 2010
Goodman gas furnace model number gms80904bna won't light. Changed the flame sensor and the ignitor is bright orange please help
Obvious that the unit isn't getting gas to the ignitor.
To receive gas to the ignitor, there is a gas valve located upstream of the burners.
Have a friend turn on the heat while you are up close to the furnace.
Once the ignitor gets hot, there will be an audible "click" at the gas valve when the low voltage controls call for the gas valve to open to supply gas to the burners.
Listen for it.
If you hear a click, and the furnace still isn't firing, you need to check to see if someone has closed the gas shut off supply valves located on the gas line.
If all the shut off valves are open, you need to verify you have gas pressure in front of the gas regulator.
If you verify have pressure on the upstream side of the regulator, you will need to verify there is also pressure downstream of the regulator.
If there is gas pressure upstream but none downstream, replace the regulator.
If you have pressure downstream of the regulator, and the gas valve clicks, but furnace doesn't light, replace the gas valve.
LP has higher pressure than natural gas, and is dangerous.
LP is heavier than air and will sink to the floor or lowest area.
One static electricity spark is all it takes and an explosion can occur.
GMS80903BNA goodman furnace. Short cycling
I have the same problem. The vent flu. Is building up condensation and running back into the furnace and cloggs the little black vent hose with water. Then it comes back on then off etc.
somehow the trick is to make as straight of an upward vent flu as possible ( definitely not 45 degree elbows and really not 60's either) seal all connections with glue.
