20 Most Recent
HP Pavilion a6600f Desktop PC Questions & Answers
HD535-2w code on hadware diagnostic
This is a ram surface scan error. I highly recommend this website as it fixed the same error for me on Dell system. The link is as below :http://error-tools.com/error_codes/?t202id=978&t202kw=&OVRAW=error%20code%20hd535%202w&OVKEY=error%20code&OVMTC=advanced&OVADID=37585466513&OVKWID=394582579513&OVCAMPGID=1288200513&OVADGRPID=13190030401&OVNDID=ND1Copy and paste this into your browser and in just a little while you will be not even know you had the problem. I hope this helps.
My hp pavillon a6600f make
Shut down and unplug your computer.
Unscrew the two screws on the back of the case and open the side panel of the case.
Remove your RAM memory stick(s) from their holders.
Replace them into their respective holders again.
Ensure they are seated properly and clipped in.
Plug your power cord back in and see if your computer will boot. You can leave the side panel off just don't stick your fingers in there when it's plugged in.
If the problem persists, then you may have one or more bad RAM memory sticks.
If you have more than one stick installed, try removing one and reboot.
Always unplug your PC before removing RAM sticks and try not to touch the copper contacts on the RAM stick to avoid static damage, they can be delicate.
Good luck and please post back about how you make out.
How do i rename my
Hi Positive 725,
Good day!
I understand that you would like to change your computer name.
Here are some ways for you to do so:
For Windows Vista and Windows 7
Option1.
1. Right click on the Computer option and select on "Properties".
2. Click on Change settings.
3. Type in your desired Computer name.
Option2.
1. Click on Start or the Windows Orb.
2. Select Control Panel.
3. Choose System.
4. Click on Change settings.
5. Type in your desired Computer name.
For Windows XP.
1. Right click on My Computer icon then select on Properties.
2. Click on the Computername tab.
3. Click Change to rename the computername.
4. Type in your desired Computer name.
I hope this helps.
Best regards,
Jheycie =)
Will not boot, error msg \boot\memtest.exe
Ok if you have dos as in start>run> type chkdsk in the run window and hit enter. You can try F2 during start up after you see the logo and select using arrow buttons safe mode and enter and then go to system restore in the start menu. If you can do any of this reply and I will give you more details.
I have an HP Pavilion
HP has written a SoftPaq
that updates the monitor driver to resolve this issue. Download the
SoftPaq and read the instructions carefully before proceeding.
HP SoftPaq Number SP33741 titled,
HP LP2065 LCD Monitor Driver
, Version 2.00, Revision A (or later) is
available online from HP. Use the following links to download the
SoftPaq and the SoftPaq Instructions:
SP33741 File Download
SP33741 Instructions/Information
The video card on my
When you install a compatible video card to your PC, it's automatically detected, and therefore, overrides the onboard video. Be sure that it's seated correctly else you'll encounter problems. Sometimes taking the card out and putting it back in fixes the problem. Also, be sure that your PSU (power supply unit) is capable of handling the new card. There are usually specs listed on the box which inform of the right amount of amp-age of the PSU required to match up with the video card.
Hope this helps. :)
At start up my monitor
the most likely issue is the computer's graphics card. to avoid extra problems, try replacing it with the same model graphics card.
