20 Most Recent
Samsung TABLET PCS SAMSUNG | NP-Q1-V004 RTL PC Notebook Questions & Answers
Maquina de lavar Samsung wf90f5e5u4w
ENGLISH ONLY please.
Samsung washing machine wf90f5e5u4w
Hello good afternoon, I want to ask for help, I have a faulty module and I wanted to ask if you have the electronic diagram for the Samsung DC92-01240C washing machine, the machine model wf90f5e5u4w, I would really appreciate it if you could, thank you. greetings Antonio Paulo
Steam Wash, Washers Support ' Samsung Care US
Samsung
https://www.samsung.com > washers > front-load > ste...
Get the latest drivers, manuals, firmware, and software. Learn more. Request repair service. Arrange for a service visit at home, schedule a walk- ...
https://www.google.com/search?q=Samsung+DC92-01240C+service+manual
12/4/2023 10:19:25 PM •
Samsung...
Answered
on Dec 04, 2023
Getting WGN - TV on Samsung television?
That sounds like a voice command problem for this Chicago, Illinois based channel. Refer to the station by its number on your subscription package, like "Alexa channel 1105 on tv".
https://www.google.com/search?q=wgn+-+tv
Use Alexa with your Samsung TV or smart monitor
Samsung
https://www.samsung.com > answer > ANS00087622
Amazon Alexa is now built-in on Samsung TVs and smart monitors! You can ask Alexa to change the channel, open apps, search for movies and shows, play music, ...
How to connect your Samsung smart TV to Alexa
Tom's Guide
https://www.tomsguide.com > How-to > TV
Apr 5, 2023 - Step 1: Set up your devices. First, make sure that both your Samsung TV and your Amazon Alexa device are set up and workings.
Can Alexa change TV channels? As long as you're using the TV's built-in tuner, you can use Alexa to change TV channels. Just say something like "Alexa, channel 7 on TV" or "Alexa, change channel to [channel name] on [TV name]."Nov 1, 2022
8/31/2023 5:09:22 PM •
Samsung...
Answered
on Aug 31, 2023
Samsung SGH-J700. I can't open .jar files from MicroSD on it.
It is a JDK Java X Runtime file
However, if you are still not able to run the file, here's what you can do:
- Right-click on the JAR file.
- Go to "Open With Other Applications".
- Select Show other applications.
- Select Open With OpenJDK Java X Runtime.
- If you don't find the Java option, install JRE.
Jun 25, 2023
How To Run & Open A JAR File (.JAR File Opener)
Software Testing Help
https://www.softwaretestinghelp.com > how-to-open-a-ja...
How to Open JAR Files on Windows 10 and 11
How-To Geek
https://www.howtogeek.com > Windows
Jul 5, 2022 - To run a JAR file on Windows 10 or Windows 11, right-click it, then select Open With > Java Platform SE Binary. Alternatively, you can view ...
What Is a JAR File and How... ·
Step 2: Download and Install...
How to open a JAR file
TheServerSide
https://www.theserverside.com > blog > How-to-open-...
Jun 7, 2022 - Change the extension of the JAR file from .jar to .zip · Right-click on the JAR file and select Extract All · View the contents of the open JAR ...
How to Open a Jar File
Computer Hope
https://www.computerhope.com > ... > Software Help
May 1, 2023 - Manually choose program to run jar file · Right-click the file and select Open With. · In the Open With window, click the Browse button to open ...
8/12/2023 5:59:26 PM •
Samsung...
Answered
on Aug 12, 2023
Samsung video security system model sds p5102 cant get to load past 1/4 of bar at start up screen
Here are some troubleshooting steps you can try:
- Restart the system: Turn off the system and unplug it from the power source. Wait a few minutes, then plug it back in and turn it on.
- Check the connections: Make sure all cables and connections are securely connected and not damaged.
- Reset the system: Try resetting the system to its default settings. This can typically be done by pressing and holding the reset button on the back of the DVR for several seconds.
- Update the firmware: Check if there are any firmware updates available for your system and install them if necessary. You can usually find firmware updates on the manufacturer's website.
- Contact Samsung support: If none of these steps work, you may need to contact Samsung support for further assistance. They may be able to diagnose and resolve the issue or provide you with options for repair or replacement if necessary.
It's important to note that working with a security system can be sensitive and may require the assistance of a professional. If you are not comfortable troubleshooting the system yourself, it's recommended to contact a professional installer or Samsung support.
3/21/2023 7:12:40 AM •
Samsung...
Answered
on Mar 21, 2023
What does error code Ee with the degrees Fahrenheit showing mean on a Samsung RF26HFENDSL Refrigerator ?
Error code Ee with the degrees Fahrenheit showing on a Samsung RF26HFENDSL refrigerator typically indicates a communication error between the refrigerator's main control board and the temperature sensor. This error can be caused by a faulty temperature sensor or a problem with the main control board. It's recommended to check the sensor wiring and connections or call a professional to check the main control board.
2/27/2023 11:51:03 PM •
Samsung...
Answered
on Feb 27, 2023
