20 Most Recent Element Electronics Zr-Element Digital Media Player Questions & Answers
try the manufacturer's website . GOOGLE SEARCH Google
Element... | Answered on Dec 24, 2017
This function prevent you from unknowingly pressing some keys/touch pad.So you can peacefully listen to songs
Thank You
Element... | Answered on Sep 03, 2010
it shuts down may be because of virus you may scan it and cure it and some songs may be of any other file format which don't work in ur device so you may change the format ! ! !!
Element... | Answered on Jun 04, 2010
I guess the format you used wasn't the right format you used.
Get a converter and convert some other formats apart from mp3 format.i guess that will do..
Element... | Answered on Feb 16, 2010
what loading screen? you mean the refreshing updates
Element... | Answered on Feb 06, 2010
Ok, go to this tip here on this site here is a link -> http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem
This guy helped me with my problem.
Element... | Answered on Jan 02, 2010
hi there
i can help you with this one plug in you mp3 in to your computer go to start on your computer than go to my computer you will see a mp3 icon where you save all your music drag it to your mp3 icon
Element... | Answered on Dec 30, 2009
You disconnected it without using the safe disconnection feature. It is easy to do because it automatically disconnects if you press play. I know because i did it too.
Solution: the only one I have heard that works is to leave it, switched off for a few days and then try it again.
Element... | Answered on Dec 27, 2009
its a corrupted file that contains viruses and can destroy you computer in seconds best way to fix this is to send me your email address
Element... | Answered on Dec 22, 2009
The following may help:
- Ensure that your Music files are of the correct format (usually .MP3 or .WMA suffix and usually NOT .WAV which is the standard CD format). - Ensure that you upload your music .MP3 or .WMA files to the correct directory and names are not excessively long as some MP3 will limit the max name length. If you know a working song on your MP3, locate the directory it resides in and put your songs there. - Lastly, if you have put your song with the correct naming convention/suffix and you now see them in your player list but they will not play, then your MP3/WMA file has non-compatible 'property' whcih is usually the encoding 'bit rate' (usually anything under 128mbps fix rate is good but you can see what is acceptable by looking at the 'properties' of your working songs that are on your MP3 player)
Element... | Answered on Dec 20, 2009
go online and contact the manufacturer or google the reset button for the media player type you have, goole should have all this readily available
Element... | Answered on Dec 07, 2009
hey. try this, go to "MyComputer" in the list of drives. if you see yours then either double click or right click and "open". there you should see at least music and videos folder. if you dont then create them name them "Music" and "Videos" now leave this open and grab the songs you want on there and drag them into the music folder. if you have a video then first it should be a .AMV format. if you dont know how to convert it then go to start-all programs-mp3 player utilities 4.18 (might be diferent numbers for different players.) and then click "AMV converter". drag the video files to the white area on the bottom of the converter and click the button that looks like two arrows opposite of each other. thats the start button.then it will take some time depending on how big the video files are. then drag the .AMV files into the "Videos" folder i told you to make. now unplug you mp3 and check. and if still no luck then write e back. hope i helped.
Element... | Answered on Dec 01, 2009
Press the << button once or twice until music plays normally. If it plays too slow, press >> button.
Element... | Answered on Nov 28, 2009
Your player takes Mini SD card…up to 2GB.
As a reference for the different types of SD cards: http://en.wikipedia.org/wiki/File:SD_Cards.svg
You can get it from best buy or any other retailer.
Cheers,
Ed
(If you liked the solution, please grade my response… please! Ed)
Element... | Answered on Nov 07, 2009
Element Electronics Zr-Element  Digital Media Player Logo
73 questions posted
Top Element Electronics Audio Players & Recorders Experts
Marvin
Marvin
Bobby G
Bobby G
ray gallant
ray gallant
Are you an Element Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Element Electronics Audio Players & Recorders
Most Popular Question
bought element 2gb mp3 player yesterday
  • Audio Players & Recorders
