20 Most Recent Samsung SPH-m510 Cell Phone Questions & Answers
contact any samsung service center
Samsung SPH-m510... | Answered on Feb 19, 2019
That file has to be in the same folder as your other ringtones are for it to be accessed. Get it in there and it will work.
Samsung SPH-m510... | Answered on Aug 26, 2017
type on the main screen "##3282#"
go down to "advanced"
then press ''view''
click right 5 times, and it reveals your lock code
Samsung SPH-m510... | Answered on Jul 16, 2013
What kind of phone is it?
IPhone = iTunes
Android + most others = Show up as an external drive when you plug them into your computer. Just browse the folders on that drive, find the one containing you pictures and then copy the pictures to your computer.
Samsung SPH-m510... | Answered on Oct 22, 2012
I believe you can just dial:
# * 7337 #
That should do a master reset.
I'm pretty sure it is the dial code up top, but if not try:
* # 7337 #
Good luck!!
EJ Kudelka
Samsung SPH-m510... | Answered on Oct 14, 2011
Hi breanne_est,It sounds like your memory is completely full!There's an easy fix to this. Go into your messages application and start deleting messages (both sent and received).After you've deleted a bunch of messages it should unlock and allow you to open up new ones!Good luck.Alex
Samsung SPH-m510... | Answered on Jun 07, 2011
Hi,you are using a Samsung phone.You can go to any Samsung store to get a replacement of screen or you can go to any Phone store where they sell phone parts and get a replacement of screen.
Hope that helps.
Samsung SPH-m510... | Answered on Sep 25, 2010
sorry this facilities not available ur mobile,
otherwise
u don't like the receive calls.
mobile switch on condition at the time remove ur mobile battery, any other persons call u said " not reachable "
Samsung SPH-m510... | Answered on Sep 05, 2010
There is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Take care.
Samsung SPH-m510... | Answered on Jul 23, 2010
Hi,here is a detailed solution to help you out;
1.Plug one end of the USB adapter into the phone, and the other end into an available USB port of your computer. Look to the bottom right of the screen and you should see an "Installing Driver..." window pop up. Wait a few minutes to allow the computer to look for a driver for your phone
2.Look for a window to pop up that tells you "Driver was successfully installed." If it never comes up, or instead a window pops up that says "Driver was not successfully installed," it means your computer did not recognize your cell phone. In this case, you'll need to look for the driver. If it did install, skip ahead to Step 5.
3.Install the driver by double-clicking on it. Before you do this, make sure your cell phone is unplugged. After you've installed the driver, plug in the cell phone, and it should be recognized
4.Go to "My Computer." Look for a new drive that has either the brand/model of the cell phone in the name, or simply a picture of the cell phone on the drive. It will probably have the drive name F:, I: or G:. Double-click on it.
5.
Go to Start > File > Settings > Folder Options and select to enable hidden files and folders to be shown. Then go back to your cell phone's folder and look around. You should see a folder with the name "Pictures," "Photos," "images" or a similar name. Double-click on it, and you should see all your cell phone images.
6.
Select images and right-click "Copy." Then go to your desktop and create a new folder by right-clicking and selecting "New Folder." Open up this new folder, right-click and select "Paste." Your images will then be copied from the cell phone to your computer where you'll be able to access them any time.
Thanks and take care
Samsung SPH-m510... | Answered on Jun 20, 2010
hope this will help you...
Select "normal" profile
Samsung SPH-m510... | Answered on Jun 16, 2010
my samsung shows half white screen,top half plus freezes on certain screen & shows static.Can u tell me whats wrong with it as im not sure if its a battery error or malfunction??
Samsung SPH-m510... | Answered on Mar 06, 2010
Telecom reprogrammed my samsung M510 now handset is locked what do I do to get it out of the lock
Samsung SPH-m510... | Answered on Feb 28, 2010
https://mypictures.bell.ca/login.do
go to this website, you can go to forgot your password and get a new password.if this doesnt work, you probley dont have internet on your phone, i called bell and the guy told me my problem was that i didnt have internet.. so idk... i didnt get interent.. and its still not working.. i hope this helps some of you.
Samsung SPH-m510... | Answered on Jan 17, 2010
Samsung SPH-m510 Cell Phone Logo
47 questions posted
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
SPH Samsung
  • SPH Samsung
Most Popular Question
want download pic 39 s from phone
  • Cell Phones
