20 Most Recent
Sierra Online, Inc. Planes, Trains, and Automobiles for Windows Questions & Answers
Engine runs hot.have ereplaced waterpump which was
1. Fill the coolant in the coolant expansion tank
2. Ensure that no coolant leaks from the radiator and pump
3. Identify the coolant bleed screw, this screw is just beside the thermostat
4. Start the engine and loosen the coolant bleed screw. Now coolant comes out with air bubbles. allow the coolant to flow until coolant comes without air bubbles.
5. Tighten the coolant bleed screw.
Empire earth 1 not running in windows 8
Empire Earth is not supported on Windows 8, . You will need to manually edit the registry. You need to open "Run" (can do it by pressing the "Start" keyboard key and then "R"), type "regedit" and then click "Ok".Navigate to "HKEY_CURRENT_USER\Software\SSSI\Empire Earth\Wait for VSync" and change it to "0" (do this by double clicking the entry).Then navigate to "HKEY_CURRENT_USER\Software\SSSI\Empire Earth\Rasterizer Name" and change it to "Direct3D Hardware TnL" (similar to how you did with VSync).
When i try to run Ultra Mini Golf Adventures, I
HI, just wondering if you have the original disc for Ultra mini golf adventures ?
the error message "A required security module can not be activated" is generated by a piece of software called securecom that is essentially to stop people pirating games.If you have any emulation software such as daemon tools or alcohol 120% (these create a temporary cd drive so that a bit of software can work with out the original cd) running remove or disable them.
If its a legit copy of the game etc.. and you have the cd then it may be an issue with the registry area of your pc
Click the start button and then click RUN
type in regedit
look for the folder
HKEY_LOCAL_MACHINE/System/MountedDevices/
Right click the folder folder, Click Permissions, Click Advanced,
Look under the "TYPE" header for any labels that say "Deny", if there
are any highlight and click Edit, Check Full Control and "OK".
hopefully this should sort the problem
If its not a legit copy or if you have emulation software running you will need to download the latest version of cureom
http://cdmediaworld.com/hardware/cdrom/cd_utils_8.shtml#CureROM
Will 83069-U18 controller work on a PS2 please?
The Nyko Core Controller 83069 is a versatile controller that is compatible with both PCs and PlayStation 3 consoles1. However, there is no specific information available about its compatibility with a PlayStation 2 (PS2). It's always a good idea to check the product's user manual or contact the manufacturer for the most accurate information.
If you have a PS3 or a PC, you should be able to use this controller. Please note that compatibility can sometimes depend on the specific model of the console and the controller's firmware version
What does code 71 on a 2013 paccar 587 mean?
Its when the Shift attempts to pull out of gear, but the Gear Position Sensor indicates that the transmission was unable to disengage that gear. and detected a system failure, and unable to detect the cause.
Solitaire Customer Service Call 1-8O5-225-6690
We are 24 Hour Available Call Now
Well you really didn't loose them.
What happens is Hp puts in the software of a whole bunch of games where after time you have to go to their site and purchase their games.
Well there are other FREE sites to goto to find Solitaire, free cell, Spyder solitaire and such.
I also think that they meybe hidden files in Windows, but to find them you have to remove Hp games and then do a search
When the game turns on
Pokemon crystal is a Game boy color game, there for it will not run the original Game boy.
What are some good catering services?
I recomenr you Alchemiq, it is a quality caterers https://alchemiq.com/catering-nyc/. They offer gourmet appetizers, fancy food stations, upscale cocktail catering, and event design
Recommended System Requirements
Find out if you can run that game on your PC Learn about. System Requirements Lab
www.systemrequirementslab.com
you can find here the minimum and required system requirements for most of the games and the updates needed for you to download to make the games run on your system.
Update profile
Clear your question, because which types of profile update. Then i better answer given.
Thanks.
Well i got the new
Unfortunately, your Logitech controller uses the DirectInput control standard, and Deathly Hollows Part 1 will only work with the new XInput standard introduced in Windows 7. The only Xinput controller so far is a 360 controller hooked into the PC. There are also some software emulation solutions, but those can be a bit tricky and buggy to use. For the best experience, I'd recommend purchasing a 360 pad and the corresponding wireless sensor.
