20 Most Recent
Haier HWR06XC3 Air Conditioner Questions & Answers
The unit ,has e-1
Here is a tip that gives a further explanation of that E-1 code. The causes ofthe E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening withyour window air conditioning unit and give you some things to try to help youget your problem resolved.
E-1 Code on Window Air Conditioning Unitsheatman101
Haier mini split E7 and exterior fan not working
On a Haier Split system a E7 error is a failure of the outdoor inverter PCB and the outdoor power supply PCB. Both will need replacing. Looking around $600 for those parts. Plus fitting. The indoor PCB is very unlikely to be needed.
Where is the drain hole
Hello, some window units do not have a drain hole for the condensate, instead the use the fan blade to sling the water on the condenser, since the condenser is warm/hot it will evaporate the condensate.
E1 on haier thermocool side by side refrigerator
That error is a freezer fan motor error, Check to see if the unit is defrosting like it is supposed to be. IF it is defrosted, check to see if the motor spins and if you have a meter for measuring resistance, check the motor windings. If they show no conductivity, Replace the fan.
