20 Most Recent
THQ Prison Tycoon 2: Maximum Security Questions & Answers
No volume
First, check to see if the volume on your computer is on. You could either click the mute button on your keyboard, or the little speaker symbol in the bottom right (if you have a PC) and increase the volume.
The next thing I would check would be if your speakers are plugged in.
Finally, if all else fails, go to the main menu on the game and play with the volume settings.
Hope that helps!
-Hunta
I have a problem with
You have to upgrade your VGA card most probably but anyway you can try the following:
Install the latest VGA drivers from Intel website which can improve performance
Install DX 9.0c to remove some glitches/bugs
The amount of graphic processing is below par for your built-in graphic card when it is unable to draw objects in real time at FPS rate of 30 or above.
Let me know if the above steps help to improve the performance of the game or not.
Playstation controller pc
ePSXe is your friend here. Emuzone is where you need to go, or just google it.
Please keep in mind that these emulators, while they may work with disk images, legally requires that you physically own the game you are trying to play.
Also having a 2 stick joypad in your computer helps in the controller configuration.
Hope that helps.
Cheers from New Zealand :D
