20 Most Recent
Electronic Arts The Sims 2: Bon Voyage Questions & Answers
Sims 2 bon voyage stops installing at 57%?
um-mm...some disc are really thin and have trouble reading the disc because it is spinning far to fast. This usually happens far to fast. You could also get a cleaning disc, that they usually have for DVD player, I don't know if they have one for the computer or not, but it would be great to look into. Also, one new thing that people aren't looking, because this happened to my DVD player, you see, my DVD player kept saying wrong disc, and it was because a battery had a whole in it, and the corrosion of the battery melted and destroyed the Lazar, as well as flowing into the jack. so I had to get rid of it before fixing it. Now, it probably can't copy the file, because your computer needs its hard drive updated, as well as the AGA Graphic memory, I had trouble with a game one because it didn't have enough graphic color for 3d flash games. So check for that. Take care and good luck.
Sims 3
Hello, please vote and testify please!
No Bon Voyage Disc 2
Well you could always download a torrent but i dont think there is a 2nd disk was it preownd?
Sims 2 bon voyage need help to install
put disk 1 it should say type in a serial number wait for disk 1 to install then it should say insert disk 2 wait for that to be install after a message should pop up saying insert disk 1
Sims2 Bon Voyage Disc 1- "Backup" problem?
If it doesn't recognise it there probably is a scratch or something like that on it, or you have disk emulator softwarelike Daemon Tools running, which causes games to block. Try closing the emulator software. If you don't have any running, you could try using a crack for the game.
A crack is a copy of the game launcher that does not look for the CD when it starts. GO to one of tese sites:
gf.wiretarget.com
www.gamecopyworld.com
and download a "fixed exe" for your version of the game. It is advisable to update your game to the latest version, and then download the late version crack.
To open the file the crack is in, you will need a program called 7zip. jJust google it and download it, it's free and perfectly safe.
Once you have the crack, overwrite the file of the same name in your Sims folder, and the game should run properly from now.
I hope this helps,
Yannick.
I can't install Sims 2 bon voyage
If you have more than 1 CD/DVD Drive then place it in the other.
If not, then restart your computer, ensure you have the latest drivers for your CD Drive (if any) and make sure that the CD Drive can read other disks!
If that doesn't work then the Disk may be faulty (suggest get a replacement)
