20 Most Recent Android Zte-z990 Questions & Answers
First make sure that all volumes are all the way up. Go to settings, sounds, and rise up all of the volume.
Second, select a notification sound for your default notification, go to settings, sounds, notifications, tap it and choose a notification sound.
Third, whether you are using the native messenger or a third party messenger, go to the messenger settings, notifications sound and choose a sound for it.
if possible, download Zedge, this will help you choosing different ring tones and notifications sound.
Android Zte-z990 | Answered on Jan 01, 2017
Try this:
•Connect the phone to your computer with a USB cable that came in the sales package with your Lumia phone. If the battery has not been used for a long time, to begin charging, you may need to connect the cable, then disconnect and reconnect it.
•Press and hold the Power button for 10 seconds, and then press to turn on your phone again.
•Your PC should detect your phone when it is connected using a USB cable, if this is not happening you can manually switch the phone into specific mode following these steps:
1. Disconnect your phone from the USB cable.
2. Hold down the camera button.
3. Continue holding down the camera button and connect the USB cable between your phone and PC.
4. Continue holding down the camera button until you see the connect-to-computer screen on your Lumia phone display.
5. Release the camera button.
6. The Zune software on the PC should automatically detect your phone now and charging indicator appears on the display.
If the tricks above does not help, you will need to contact your local Nokia Care. You can find details by clicking the Contact us link in the support pages of the Nokia website for your country.
Note: Your battery has been partially charged at the factory but when taking your new device into use, please keep the charger connected for 30 minutes. It is recommended to use original charger (AC-16).
Android Zte-z990 | Answered on Oct 16, 2013
Power off
hold the volume up button and the power button until you see the recovery console.
Choose Hard Reset
Android Cell... | Answered on Jul 18, 2019
you need to look up the process in google like this http://www.minixforum.com/threads/update-18-okt-2014-x8-h-flashable-zip-for-neo-x8-h.98/ and replace the firmware instead
After the phone has finished its factory reset it will reboot and you will be prompted to choose the desired display language. After choosing the correct language please follow the next steps:
  • Connect the phone to a Wifi Network
  • The next screen will ask you for the Google Account
  • Tap the text field in which the account should be inserted until the Keyboard comes up
  • Tap and hold the "@" character until a Settings menu pops up
  • Select Google Keyboard Settings
  • Tap on the 3 dots in the top part of the screen (or More depending on what Android OS you are running)
  • Select the Help&Feedback item and select any item in the list that will follow
  • Long press to select any text on this page and click on Websearch in the upper right corner
  • A search field will be shown (delete the text inside the search field)
  • Type Settings in the search field
  • Tap "About Phone" and tap 7 times on the Build Number to enable Developer Options
  • Return to the previous menu and open the Developer Option that just appeared
  • Allow OEM Unlocking and tap Back two times
  • Restart the device
  • Connect it to Wifi again
  • Notice how you won't be prompted to log in the previous Google Account and instead the phone will ask you to ADD a new Google Account
  • Android Cell... | Answered on Jul 18, 2019
    With the handset turned off, press and hold the Volume Down key.
    Note that a master reset will return the handset to the default factory settings and erase all personal information on the handset. All important information should be backed up before proceeding.
    can you please brief the problem, is it about the internet speed or opening the apps...
    Android Cell... | Answered on Jul 12, 2019
    A Hard Reset is the only way. Scrub the phone clean and start again.
    Android Cell... | Answered on Jul 05, 2019
    You can connect it by your usb cable.as your android support c type charging so you can use your c type charging cable...
    Android Cell... | Answered on Jul 04, 2019
    Android Zte-z990 Logo
    7 questions posted
    Top Android Cell Phones Experts
    john smith
    Steve Sweetleaf
    Steve Sweetleaf
    Dakshinamurthy...
    Are you an Android Cell Phone Expert? Answer questions, earn points and help others
    View Most Popular
    Android Cell Phones
    • Android Cell Phones
    Most Popular Question
    rethink possible loop when power up
    • Cell Phones
