20 Most Recent Field and Stream F25SLUMI Wrist Watch Questions & Answers
Watch has film inside the glass. Also, the finish
The film is from moisture getting into your watch. Moisture can get in one of 3 ways generally. The crystal if cracked, the crown, or the back. In your case since you have buttons for the mulch-functions of the watch you add a possible place for moisture to enter. Take the watch to a watchmaker or watch repair person. Your watch has to be taken out of the case and the case needs to be cleaned. Next the watch tec. may be able to see just where the seals failed and replace them. We of course do this. Also if the gasket is old or out of shape this is a culprit as well. Hope this helps, gabe
7/11/2014 9:46:08 PM • Field and Stream... • Answered on Jul 11, 2014
0answers
2answers
Compass dial turned opposite direction
you might be able to reverse the poles back to normal with a magnet but be careful not to scratch face or get it closer than you need to to the insides of the watch.
3/13/2011 8:40:14 PM • Field and Stream... • Answered on Mar 13, 2011
0answers
0answers
Leather wrist strap
I would scrap the strap - the odours are caused by the tanning chemicals getting wet. Retain the fastening and purchase half a meter of nylon ribbon loop it through the case pegs on one side glue them together and pierce for buckle holes. On the buckle side loop it through both case peg and buckle and fold and glue. You have a choice of colour and it cost only fraction of a new leather one- also you will have enough left to make two straps
9/12/2007 8:31:14 PM • Field and Stream... • Answered on Sep 12, 2007
I have a field and stream 1871 safe I forgot the pattern I do have the combo
Is this a spin dial system?
9/13/2016 11:41:21 PM • Field and Stream... • Answered on Sep 13, 2016
I need a new watchband
So go online, find your nearest Field & Stream dealer and order one of your liking. You need to post on fixya for that??????
5/30/2016 6:11:07 PM • Field and Stream... • Answered on May 30, 2016
F&S FE6B-1 battery replacement
It will either unscrew if evenly spaced notches exist around the cap's edge if threaded or snap off if a small cavity exists beneath the cap's edge to insert a jeweler's screwdriver.
8/9/2014 2:23:17 PM • Field and Stream... • Answered on Aug 09, 2014
0answers
Battery
Be the first to answer 3/15/2014 3:19:23 AM • Field and Stream... • Posted on Mar 15, 2014Be the first to answer
Field and Stream F25SLUMI Wrist Watch Logo
Popular Tags
12 questions posted
Top Field and Stream Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Field and Stream Watch Expert? Answer questions, earn points and help others
View Most Popular
  • Field and Stream Watches
Most Popular Question
watch film inside glass also finish
  • Watches
