20 Most Recent Aeris Max Depth Analog 2 Gauge Console Questions & Answers
Scuba tanks can be filled well past 3200psi. When they do a hydrostatic test it is well beyond any pressure that any dive shop will fill a tank to. The highest I've seen the pressure get in my tank is 4000 and that is when the filler at the dive shop forgot about it.
Aeris Max Depth... | Answered on May 30, 2011
You may need to take it to an authorized dealer
http://www.diveaeris.com/dealers.asp
or contact aeris directly for support:
http://www.diveaeris.com/contact.html
Aeris Max Depth... | Answered on Jul 31, 2009
Pressure gauges are sealed and should not ever get bubbles in them. If there's air in the gauge, there's some possibility the Bourdon tube has a crack in it. You will spend more time dinking around with getting a bubble out and resealing the gauge than the instrument is worth. The pressure gauges on a fill station are industry standard parts and you can buy replacements off the shelf. They're not terribly expensive. Replace it.
Aeris Max Depth... | Answered on Dec 01, 2008
Scuba gauges give a diver three very important pieces of information: 1. Time 2. Depth 3. Air Consumption This information enables a diver to stay within safe time and depth limits and avoid running out of air. There are many different devices on the market to help with this, from simple gauges to complex digital consoles. Time If a diver is not using a dive computer to monitor their nitrogen, they dive according to approved dive tables. To use dive tables properly, a diver needs to track their downtime. This can be done with a good dive watch. Two things make a good dive watch: water resistance and a rotating bezel. 1. Water Resistance. Good dive watches are rated to a depth in meters or feet (e.g. 200 feet) or a pressure rating in atmospheres (e.g. 4atm). Even though most divers probably won’t dive below 130 feet (the recreational dive limit), a good dive watch should be rated to 200 feet. Note: There is a difference between “water resistance” and “waterproof”. A “waterproof” watch is what you would wear in the shower, but would probably start leaking at 15-20 feet. 2. Rotating Bezel. A bezel is an adjustable ring on the face of the dive watch with a pointer indicator. At the beginning of a dive, the pointer on the bezel is aligned with the minute hand where it stays though out the dive. At the end of the dive, you compare the difference between the bezel and the minute hand to find out the length of the dive. The bezel should only move “counterclockwise”. It is possible to accidently move the bezel during a dive. Because of this, watchmakers make sure any accidental movement will turn the time in a conservative direction, making the dive longer rather than shorter. Depth Another important part of scuba gauges is a depth gauge. A depth gauge enables a diver to keep track of their depth even if they cannot see the water’s surface. Gauges can be either an analog (needle-and-dial) device or a digital device. Both work in the same way. They measure the surrounding water pressure and convert this into an accurate reading of your depth. Another feature of a good depth gauge is a maximum depth indicator. This tells a diver their maximum during a dive and must be reset after each dive. Air Consumption Another equally important part of scuba gauges is a submersible pressure gauge (SPG). This is connected to the first stage with a high-pressure hose and measures the pressure of the air in the tank. The SPG is much like the gas gauge on a car. At the beginning of a dive, a diver starts with a full tank. This should be about 3000 psi or 200 bars. As the diver breathes during the dive, the gauge will move slowly downwards. This allows the diver to have enough air left in the tank to: 1. Make a slow, safe ascent 2. Make any necessary decompression stops 3. Inflate their BCD once at the surface 4. Breath from the regulator if the surface conditions are rough A submersible pressure gauge also allows a diver to stop diving with air still in the tank. This keeps contaminants from entering the tank due to no air pressure. Wrist Depth Gauge Scuba gauges come in two basic styles. Stand alone gauges or gauge consoles. Stand alone gauges such as a wrist mounted depth gauge or a submersible pressure gauge attached to the first stage of a regulator are great backups when using digital gauges. Gauge consoles allow divers to have all their gauges in one place. Although less easy to read, analog gauges sometimes give slightly more accurate readings than digital gauges, particularly at shallow depth. Submersible Pressure Gauge Choosing Scuba Gauges When choosing scuba gauges, remember to look for: 1. Easy-to-read numbers 2. Luminescent dial or back lighting options 3. Rotating/swivel mounting 4. Easy disassembly for cleaning or replacing parts 5. Good warranty
"It's probably sand, rinse it well in strong running water and it should be fine. I had a compass once get sand lodged in it and prevent it's rotation, a strong rinse fixed it. Sand can only get where water travels, so if sand got there you can rinse it out with water."
"A diver relies on scuba gauges to know three things: 1.-Depth 2.-Air Consumption 3.-Time Depth and Time are vital for nitrogen and air management. A scuba diver needs to know how deep he has been and for how long in order to judge the necessity and length of decompression stops and to calculate residual nitrogen for repetitive dives. The time of a dive is easily tracked using a scuba diving watch and the depth is tracked using a depth gauge. "
You should use sheet masks as there are lots of benefits of using it. You would get an idea by looking at the following points:
1. They are ready to use and you would be free from the complex application process.
2. You will get the results in just 20 minutes.
3. Relieves stress
4. You can take Korean sheet mask along with you on your business trips.
Scuba Diving &... | Answered on Jul 04, 2018
who knows what is a sheet mask? seems this is not a repair question on a repair forum
Time plays a very important role in using the sheet masks. You should never leave the sheet mask on your skin for more than 20 minutes and forget about using it overnight. 20 minutes is enough to pass the important ingredients from the skin to your skin. Korean Skincare is known for its reliable beauty products that you could opt for and get a healthy skin.
This is one of the biggest mistakes people usually commit while using sheet mask. People think that there is alot of excess serum in the mask and so they can reuse it. This should not be done. All the dirt and bacteria will get reintroduced to the skin. Choose a quality sheet mask that is able to remove all the dirt and dead cells from your skin. Korean Sheet Mask is one such product that is trusted for its quality.
Aeris Max Depth Analog 2 Gauge Console Logo
10 questions posted
Popular Products
Top Aeris Scuba Diving & Snorkeling Experts
David Bugden
David Bugden
ray gallant
Bill Boyd
Are you an Aeris Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
View Most Popular
  • Aeris Scuba Diving & Snorkeling
Most Popular Question
aeris user manual dive computer
  • Scuba Diving & Snorkeling
