20 Most Recent Genesis Scuba Regulator Octopus S.K.O. Octopus Questions & Answers
Genesis
Hello, there are a few things that may have happened. Often octos pick up sand and grit when they get dragged on the bottom. Try a good vigorous shake in fresh water. After that your moving into badly seated diaphram, split diaphram or slight hole, badly adjusted spring etc etc etc. Would recommend that perhaps you get it serviced. Especially important if you have been using Nitrox. Hope that helps
11/5/2010 10:02:59 AM • Genesis Scuba... • Answered on Nov 05, 2010
I own an Genesis react pro nitrox/air computer but
The instructions are not in the manual. If your is a few year's old, then press the left button to get to the temp screen.
Then press both buttons simultaneously and you will get a screen that says CLR and ID and a number xx xx.
Use right button to change the first number to "7". Press the left button to once advance to the next number. Use the R button to select "19". The screen should now say CLR ID 7 19 and the 19 is flashing.
Press the L button and the computer will power off and will erase all dive logs.
Our family has a total of five React Pros and this works on all of them except the one I recently purchased (May 2010). I think they changed the code on the new ones.
7/3/2010 9:37:52 PM • Genesis Scuba... • Answered on Jul 03, 2010
I need a Zeagle Ranger technical manual.
ask them maker for that or google all week, get lucky?
6/29/2023 11:24:41 PM • Scuba Diving &... • Answered on Jun 29, 2023
Im getting condensation between the mask and the head gear. I'm using a airtouch F20 fullface mask cushion
Try to spray the commercial available mist to lower surface tension in order to avoid build-up of condensed water
11/2/2018 10:37:22 PM • Scuba Diving &... • Answered on Nov 02, 2018
How many time is normal mask life ?
it depends on the quality of the mask and it depends on how you stored it (if you leaved it at sunlight, if you washed it thoroughly after using it in the sea...) i have a mid quality mask Mares mask, i have been using about 20 times for snorkeling, then i used it to take diving certifications in pool, then i used it for about other 20 dives in the sea... i always stored it in a dark bag (the mask is now about 8 years old) you can check if you mask is still in good shape, and the silicone has not worn out, in this simple way: just put the mask on your face without straps.. remove all the air inside the mask by inhaling with your nose.. then look at your feet (keep inhaling): if the mask remains on your face you can keep using it
7/29/2017 10:42:35 AM • Scuba Diving &... • Answered on Jul 29, 2017
Prosub atmosair rebuild manual I have an older prosub that I got a rebuild kit for but need instructions to take it apart and rebuild it.
You need to consult with a factory technician. Your life depends on these devices. I am certified in USD Survivair and no one can set those after a rebuild kit without special tools and measuring devices.
7/26/2015 1:45:33 AM • Scuba Diving &... • Answered on Jul 26, 2015
2answers
Is it real?
Yes...the octopus does exist.
3/2/2015 2:52:10 AM • Scuba Diving &... • Answered on Mar 02, 2015
If i lay a pipe 6 inches below the surface of the
I would say no. The water in the pipe that is above sea level will drop back in the pipe until it reaches sea level. Provided neither end of the pipe whether above or below the sea is blocked the level in the pipe will always find natural sea level so it wont be higher or lower than sea level. So in answer to your question No it wont pour out.
6/18/2014 3:17:16 PM • Scuba Diving &... • Answered on Jun 18, 2014
Suunto companion
5/16/2014 12:56:40 PM • Scuba Diving &... • Answered on May 16, 2014
I have a CWU-62/P anti exposure suit military
Most scuba stores can provide you with the glue.
1/10/2014 11:30:00 PM • Scuba Diving &... • Answered on Jan 10, 2014
Hi Folks I think everyone thought I have a baby
I noticed another FixYa guru here answered a question on another strand that applies to yours: Also, please note this person on FB claims to be the Lemax fix-all guru. You can ask them more specific questions:http://webcache.googleusercontent.com/search?q=cache:0YBPB3sM28kJ:https://www.facebook.com/eHobbyTools%3Ffilter%3D2+&cd=10&hl=en&ct=clnk&gl=us The Knex website has building help for this problem. There answer is as follows: Make sure all rods and connectors are fully hooked together, especially the blue and gray connectors. Even one peice not fully hooked together can twist the model just enough to jam the gears. (You may have it hooked together correctly prior to jam problems so it is good to check since I found a loose on holding the motor.) The chain links need to all be attached in the same direction, and fully hooked. The chain also needs to be on the tower with the hooks facing down and in as the chain runs on the outside of the tower. (Chain should be outside on the front and inside in the back with the 5 yellow bar side in the front.) Check that all gears are positioned correctly according to the instructions and the teeth facing the correct way. If you are still unable to get the seat to drop, you may remove the top yellow cross rod that the chain runs over - the model will also work with this piece removed. I did all of these steps with my son and his still had trouble dropping all the time. It still seems light so the seat didn't have enough weight to drop with gravity during the non-moving cycle of the orange half gear. We decided to tape on 2 marble passengers to see if that helped. It did!!! When searching for other solutions, I noticed a UTube video that added people also so this seems to be a common solution. Try it or some other light weight added and see if it solves your problem.
11/20/2013 7:45:07 AM • Scuba Diving &... • Answered on Nov 20, 2013
I am looking for a
You're talking ancient history here. You might find a manual, but critical parts were unobtanium many years ago. Display it on a wall and call that good.
11/7/2013 1:25:20 AM • Scuba Diving &... • Answered on Nov 07, 2013
2answers
My netbook is net broke
Hello, There is one thing on some computers that will restart it like the day you bought it, see if there is a very small symbol that looks like a shooting star taking off from the ground and making a U turn and back down that\'s the best I can do for what it looks like, it will be only about 1/8 th in. tall and 1/16 th in. wide very small, it should be close to the power on button on your comp. this is a Rescue System to start all over from day one, I have a Lenovo G570 Laptop and it has one of these, thank god as my comp. got a very sick and would not even let Windows start up I pushed this button and I was able to clear all the stuff that was stopping it from opening, if your lucy you will have something like this on yours, Look it over real close to find this symbol, sorry I don\'t have a pic. for you, you could also check if there is a Tech. help line for your brand of comp. Well I hope this may help in some way, and get you back on line.
8/22/2013 8:03:32 PM • Scuba Diving &... • Answered on Aug 22, 2013
Locked code in safe
What I think will solve your problem is dynamite????
3/30/2013 10:15:02 AM • Scuba Diving &... • Answered on Mar 30, 2013
2answers
My spairair system has a slow leak, how can i fix
Dave,
Good luck with that...... A MUCH more reliable way to go is a small pony bottle, say a 13cf with an inexpensive reg and a pressure gauge /plug or better yet a regular SPG.. That way you have a real reg with a whole lot more air with which you can more comfortably share air or hopefully save yourself or do a bit of a safety stop on the way up.
3/12/2013 7:35:49 AM • Scuba Diving &... • Answered on Mar 12, 2013
What type of information do dive computers display?
Dive computers display a large variety of information relevant to the diver's needs. Such information includes: Current depth, elapsed dive time, and how much time remaining the diver has before having to make decompression stops.
2/6/2013 12:20:44 PM • Scuba Diving &... • Answered on Feb 06, 2013
What are the main manufacturers of dive computers?
The main manufacturers of dive computers are: Oceanic, Aeris, Suunto, Mares, Sherwood, and Tusa.
2/6/2013 12:20:10 PM • Scuba Diving &... • Answered on Feb 06, 2013
How much do dive computer batteries cost?
Dive computer batteries generally cost between $10-$20 (AA, cylindrical). Coin batteries are cheaper and are sold for a few dollars. For a complete list of batteries, check out these websites: http://www.batteryweb.com/divebattlist.cfm and http://www.batteryprice.com/divecomputerbatteries.aspx
2/6/2013 12:19:41 PM • Scuba Diving &... • Answered on Feb 06, 2013
Genesis Scuba Regulator Octopus  S.K.O. Octopus Logo
2 questions posted
Top Genesis Scuba Diving & Snorkeling Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Genesis Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
View Most Popular
  • Genesis Scuba Diving & Snorkeling
Most Popular Question
genesis
  • Scuba Diving & Snorkeling
