FixYa.com
Proteam Alpine CM DT100 Bagged Wearable Vacuum
All Products > Proteam > Vacuums
Problems with Proteam Alpine CM DT100 Bagged Wearable Vacuum?
Search inside Proteam Alpine CM DT100 Bagged Wearable... Knowledgebase
Troubleshooting and Support
Solved Problems for Proteam Alpine CM DT100 Bagged Wearable Vacuum RSS Feed Post a New Problem
My vacuum seems better when the bag is...
My vacuum seems better when the bag is empty, is it possible?
1 Solution
I have a feeling the original problem was...
I have a feeling the original problem was a result of vacuuming up dog hair (I have 2 huskies), but I always kept the...
1 Solution
dirt devil bagless vacuum. when vacuuming...
dirt devil bagless vacuum. when vacuuming a carpet, it picks up very, very poorly. but the suction is fine - when i use...
1 Solution
Unable to Extract Water
I am able to shampoo but the unit is not extracting the water from the carpet.
1 Solution
Black And Decker Gw150 Forgotten How To...
I have had this model for several years but have not used for a while. I was wondering if you could help me start...
1 Solution
changing belt
changing belt on hoover runabout
Post a Solution
Oreck Vacuum troubleshooting
My Oreck Upright has started spitting out what I want it to suck up. I'm going to try replacing the belt, but someone...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Feature
DesignWearable
Dirt CaptureBag
Motor
Consumed Power802 Watt
Voltage110 - 120 V AC
Amperage7.2 Amp.
Suction
Waterlift63 in.
Airflow112 cfm
Filtration
Filtration Levels4
Convenience
Cord reach35 ft.
Hose Reach3 ft.
ColorBlue
Weight
Weight7.56 lb.
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
