20 Most Recent
Norcold Inc Norcold 1210IM Refrigerator Questions & Answers
Russell Hobbs Fridge not working?
Humming is a classic sign that the start / run capacitor for the compressor has failed. Call for service, have it checked for gas and condenser cleaned.
How to remove drip tray at back of aeg fridge
On an AEG SANTO 3533, the tray sits on top of the compressor. There is a short metal "tunnel" on top of the compressor. The tray has a plastic clip in the middle which goes through the tunnel and latches up on the other side. To remove, reach to the back of the metal in the middle of the tray, press the plastic clip firmly down, and pull/wiggle the tray backwards horizontally to remove. Needed a torch to see clearly on mine. One of these things that's easy once you've done it once.
When Should You Consider Copper for Water Storage?
Copper has anantibacterial effect. Studies recommend storing water in copper containers for several hours before consumption to maximize this benefit. Some research suggests 48 hours. perhaps explore dedicatedcopper water bottlesfrom reputable sources for optimal water storage.
This refers to water, not juices.
Where is the defrost timer located in hisense upside down fridge freezer on model NO# HR6BMFF520S
The defrost timer in a Hisense upside-down fridge freezer, model number HR6BMFF520S, is typically located within the control panel or the refrigerator compartment. Here are the general steps to locate it:
- Check the Control Panel: Start by inspecting the control panel of the refrigerator. Look for any knobs, buttons, or switches that control the defrost cycle. The defrost timer may be integrated into this panel.
- Inside the Refrigerator Compartment: If you don't find the defrost timer in the control panel, check inside the refrigerator compartment. It might be located near the temperature control settings or the light fixture. You may need to remove any covers or panels to access it.
- Consult the User Manual: If you're having trouble locating the defrost timer, refer to the user manual that came with your fridge freezer. It often contains detailed diagrams and information about the location of various components, including the defrost timer.
- Contact Hisense Customer Support: If you're still unable to locate the defrost timer, consider reaching out to Hisense customer support for assistance. They can provide specific guidance based on your refrigerator model and help you locate the timer.
Once you've located the defrost timer, you can follow the manufacturer's instructions for troubleshooting or replacing it if necessary.
