20 Most Recent Dometic HZB-15S Portable Ice Maker Top Load 120V Camper Trailer RV Questions & Answers
possible calcium deposits
Dometic HZB-15S... | Answered on Oct 03, 2017
check water flow
Dometic HZB-15S... | Answered on Jun 03, 2016
maybe bad start up capacitor
The link below will give you lead to a supplier. I don;t know anyone at this dealer but hopefully you will get the parts you need.
Dometic HZB 15S Portable Ice Maker 120 Volt RV Parts
Dometic HZB-15S... | Answered on Feb 21, 2015
Mine was having the same issue. The trouble-shooting section of the owner's manual mentions cleaning it but doesn't state where it is at. When I contacted Dometic they stated it is in the center of that circular hole in the bottom of the water resovoir, however, they couldn't tell me how to remove it.
Through trial and error, I found that it's just a little basket that fits snugly inside that hole. You DO NOT have to remove the round part that you can see. I used a pair of pliars in an attempt to remove the entire thing and the little basket (looks like a clear plastic thimble) came right out of the center. (If you have good hand strength you can likely just pull it out without using pliars.) I cleaned that off, placed it back into the ice maker and we are back in business. It is making ice as it should now.
Dometic HZB-15S... | Answered on Jan 16, 2013
check fuses in back board and fusible link on back wall by chimney
Dometic... | Answered 19 hours ago
This one is easy your thermostat is gone. You may notice the unit never shuts off.
Dometic... | Answered on Jan 13, 2018
For Dometic parts it's usually easy to go through your local RV dealer. Not always the cheapest way, but they'll get the right parts the first time, maybe even have some of what you need on the shelf.
Dometic... | Answered on Jan 11, 2018
possible bad temp sensor
Dometic... | Answered on Dec 13, 2017
check regulator if ok check lines to pilot assembly and burn tube
Dometic HZB-15S Portable Ice Maker Top Load 120V Camper Trailer RV Logo
Popular Tags
13 questions posted
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Dometic Refrigerators
Most Popular Question
compressor runs no ice poor water in
  • Refrigerators
