20 Most Recent Dometic CF-050DC CF-50 Waeco CoolFreeze Portable Fridge Freezer DC Onl Questions & Answers
bad thermistor
Dometic CF-050DC... | Answered on Oct 06, 2017
RV Refrigerator Stop Working? - RVing - Fun Times Guide
rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Dometic CF-050DC... | Answered on Dec 28, 2015
ARE U SURE ITS THE THERMISTOR I WOULD NOT REPLACE B4 CHECKING AND TESTING IT WITH A METER? uSUALLY WHEN U HAVE A FREEZ PROBLEM ITS EITHER IN THE DEFROST TERMINATOR NOT UR THERMISTOR , ALSO COULD BE IN UR DEFROST TIMER.
AT TIMES The fan usually stops working due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS .
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM
Dometic CF-050DC... | Answered on Apr 04, 2015
This company website is: www.waecousa.com
SPECIFIC product information
including "for service" suggestions, is here:
http://www.dometic.com/enus/Americas/USA/RV-Products/Portable-Refrigerators/products/?productdataid=81811
You can download the product manual
at the (elsewhere) link below - however it does not include the error codes:
Download Manual - DreamMaker Hot Dog Carts:
www.dreammakerhotdogcarts.com/manuals/cf-series.pdf
Lastly, while not what you specifically asked for, here is their (lengthy!) 'Plan B' contact information. Hope this helps!
For RV products:
Customer Support Center
2320 Industrial Parkway
Elkhart, IN 46516
Phone: 1-800-544-4881
CustomerSupportCenter@DometicUSA.com
Sales and Marketing
Elkhart, IN 46516
Phone: 574-294-2511
Fax: 574-293-9686
Recall Department
Dometic Corporation
Recall Phone Numbers:
Servicers: 888-803-0013, press 3 and enter your account number Consumers: 888-446-5157
Recall Fax Number: 574-389-3955
For Marine products
SeaLand and VacuFlush toilet systems and products
Dometic Corporation
Sanitation Division
P.O. Box 38
Big Prairie, OH 44611
Sales and Customer Service
13128 State Rt 226
Phone: 1-800-321-9886
Phone: 330-439-5550
Fax: 330-496-3097
sealand@dometic.com
For Dometic's air conditioning systems
including Cruisair and Marine Air Systems,
and other Adler/Barbour, Grunert, Eskimo Ice
and Sentry products -
Dometic Marine Division
2000 N. Andrews Ave.
Pompano Beach, FL 33069
Phone: 954-973-2477
Fax: 954-979-4414
Tech Support 8:00 AM to 5:00 PM ET: 800-542-2477
Tech Support After Hours & Weekends: 888-440-4494
MarineSales@dometicusa.com
Marketing Division
Phone: 954-973-2477
Fax: 954-970-8703
For Truck products
Dometic Corporation, Environmental Division
P.O. Box 15299
Richmond, VA 23227
Phone: 804-746-1313
Fax: 804-746-7248
sales@dometictruck.com
For Hotel products
Toll Free: 800-301-8118
lodging@dometicusa.com
Dometic USA
PO Box 490
Elkhart, IN 46515
Phone: 574-294-8665
Fax: 574-294-3369
Dometic CF-050DC... | Answered on Nov 10, 2014
check fuses in back board and fusible link on back wall by chimney
Dometic... | Answered 19 hours ago
This one is easy your thermostat is gone. You may notice the unit never shuts off.
Dometic... | Answered on Jan 13, 2018
For Dometic parts it's usually easy to go through your local RV dealer. Not always the cheapest way, but they'll get the right parts the first time, maybe even have some of what you need on the shelf.
Dometic... | Answered on Jan 11, 2018
possible bad temp sensor
Dometic... | Answered on Dec 13, 2017
check regulator if ok check lines to pilot assembly and burn tube
Dometic CF-050DC CF-50 Waeco CoolFreeze Portable Fridge Freezer DC Onl Logo
13 questions posted
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Dometic Refrigerators
Most Popular Question
waeco cf 50 keeps freezing food
  • Refrigerators
