20 Most Recent Hobart HL600 Legacy Stand Mixer Questions & Answers
Hi,im a hobart tech and know all these mixers well.What kind of mixer are you looking to write about?The differences are the sizes of bowls as 20qt,30qt,40qt,60,qt,80qt,140qt.Pick a mixer and i will write YOUR paper,but i want a fixya rating in return.
Hobart HL600... | Answered on Apr 10, 2019
"If the error code is flashing - wait for mixer to clear error condition. If mixer continues to stop and timer displays flashing error code, disconnect electrical power from mixer for 1 minute, then reconnect. If symptoms still exist, contact your local Hobart Service office."
https://www.alfaco.com/wp-content/uploads/2016/11/HL600-HL600C-HL662-Manual.pdf
Hobart HL600... | Answered on Feb 19, 2019
Hello & Welcome to FixYa
Please get back to me with a detailed question about your Hobart as the question is still unclear because trouble code is not written.
Kevin
Hobart HL600... | Answered on Jul 17, 2018
Hobart mixer, HL300, stops and flashes as oc3, wounded what is broken?
Hobart HL600... | Answered on Jan 25, 2018
The manual I just read says to unplug the unit from wall an allow to set for a couple of minutes. This will reset it. An code should go away. If not contact service for repair. Their web page has a service manual you can down load. Maybe repair yourself if possible. I would do the reset first.
Hobart HL600... | Answered on Feb 04, 2016
It's meant to tell the operator that the bowl is not in proper operating position. If the bowl is in the proper position then the bowl in switch may be bad.
Hobart HL600... | Answered on Sep 23, 2015
Because of the very high voltage on the output of the Inverter drive, I do not want to be responsible for your injury or death from you servicing this machine without proper training.
Hobart HL600... | Answered on Aug 01, 2014
It's telling you that the bowl guard is open. If the bowl guard is in place and closed then you could have a bad bowl guard switch.
Check www.hobartservice.com for your local Hobart office.
Hobart HL600... | Answered on Jul 27, 2014
The Legacy is an electronic mixer and the transmission does not have any gear, and it frequency convertor that works in phases 2 and 3. If the hook struggling when turns, check the transmission belt locasted at the top of the mixer, remove the cover first.
If the belt is loose, tense it with the screw on the base of the motor or replace the belt. If you can not fix it, let me know and I'll try something else.
Hobart HL600... | Answered on Mar 24, 2014
There are no schematics for the reluctance drive unit to get details of every resistor, at a technician level. Perhaps try resourcing the company that makes the drives for Hobart. The troubleshooting of the drive is complex and dangerous because of residual high DC voltages. Use extreme caution while near the drive. Voltages take a while to dissipate.
Hobart HL600... | Answered on Mar 23, 2014
Hobart HL600 Legacy Stand Mixer Logo
68 questions posted
Top Hobart Food Mixers Experts
Ross Keen
Steve Allison
Steve Allison
Bruce Showalter
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
View Most Popular
Hobart Food Mixers
  • Hobart Food Mixers
Most Popular Question
manual hobart h600
  • Food Mixers
