20 Most Recent Jura Capresso C1000 Espresso & Coffee Maker Questions & Answers
Hi Lflaher
If you can't see any screws then the machine uses snap fasteners.
Until you see one of the clips & their spacing it's hard to figure out.
Use a thin clean paint scraper or credit card type tool to lift & pry one of the plastic panels until you see or feel or hear the plastic clip pop. After the first one the task becomes easier.
Take photos as you go for use on re assembly.
Check YouTube for same brand
The stuff we go through for a good coffee....
Good Luck
Jura Capresso... | Answered on Jun 09, 2016
Machine is not getting water.
Jura Capresso... | Answered on Dec 09, 2015
I've done a couple of these and it can be tricky to get the lower piston the correct height when reassembling it. Did you make sure that the entire brew group would fully cycle (the white gear travels from to to bottom) without binding before reinstalling it? It seems to me that the piston has to mesh with the gears in JUST the right configuration so that it will come to the top of its travel without biding on the housing or being to low in the chamber when it goes through the ejection phase (dumping the grounds). I don't have a fool proof method to do this other than trial and error. I'd go back and take apart the group again and make sure the lower piston is aligned correctly and that it doesn't bind when you screw the gear all the way up and down. Good luck!!!
Jura Capresso... | Answered on Apr 16, 2015
Hi, a video how to fix your Jura step by step, good luck... http://fixandparts.wix.com/nicknicoloudis#!jura-coffee-machine/c15gy
Jura Capresso... | Answered on Mar 23, 2015
Did it work before this?
Sometimes hard water can build up and cause blockages.
Try mixing hot water and white vinegar (50/50 mix) and try running it through the machine. If this works, run it through a few more times than run cold water through a couple times to get rid of the vinegar.
Good Luck.
Jura Capresso... | Answered on Oct 13, 2013
Jura Capresso C1000 Espresso & Coffee Maker Logo
62 questions posted
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Jura Capresso Coffee Makers & Espresso...
  • Jura Capresso Coffee Makers & Espresso...
Most Popular Question
went make cup only got about qt
  • Coffee Makers & Espresso Machines
