20 Most Recent Kenmore 64952 Electric Dryer Questions & Answers
Take your vent pipe off at the dryer and see it it heats if it does
it is your outide vend stoped up. If it don't heat, check all fuses,
thermastats, cutoff fuse on heat box and the heating element.
Did you clean around the blower? Hope this helps. If you removed any wires are they connected correctly?
Kenmore 64952... | Answered on Apr 23, 2013
First check the lid or door switch. If it don't agatate or spin check the coupler . Could maybe be a brake problem. Hope this helps
Kenmore 64952... | Answered on Apr 19, 2013
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
Kenmore 64952... | Answered on Nov 03, 2011
Unplug the dryer and remove it to the outside if possible.
Remove them lid switch wires off and raise upwards on the front to release the bottom clips.
You will see this:
Get the tub out and it will look like this
Get the back dust cover off
Service manual, repair videos, and MORE HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Kenmore 64952... | Answered on Jul 06, 2011
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place.
Note: This method works for most front loading machines.
Anwer to your question: Front
Basic Information...
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Kenmore 64952... | Answered on Sep 30, 2010
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Kenmore 64952... | Answered on Jul 20, 2010
Good day,
Looking might be deceptive. You'll need a VOM meter to be sure.
The resistance should be below 30 ohms on the heater.
The most common problem is the thermal fuse, which is located at the bottom center of the back. It looks like this.
It should read zero ohms. If not replace.
As well there are about 3 thermal devices located in that back area, either round or square shaped. Test all of them. They should read zero ohms as well.
Kenmore 64952... | Answered on Apr 13, 2010
you want to check the element for continutity
the resistance would be far to variable across the models to be sure i was quoting correctly
if you are reading continuity its probably good
Kenmore 64952... | Answered on Oct 21, 2009
CK,
There's a switch behind the dryer door. Push it in and out with your finger, you should here it "click, click, click" and the light should go on and off. If it doesn't, you'll need to replace the door switch.
If that's the case, I'll need the full model number. It's on a sticker on the front panel behind the door. (it should be like three digits, decimal point and about 7 more numbers... 110.*******) With that number, I'll be able to look up parts for you and guide you through this easy repair.
SG
Kenmore 64952... | Answered on Aug 23, 2009
im not sure which dryer you have but ther is a electonic control on some start buttons if you dont have that the motor is bad i would jump start swich for now it will last a long time
Kenmore 64952... | Answered on Jul 05, 2009
Get a putty knife and release the spring clips holding the panel on
Kenmore 64952... | Answered on Jun 09, 2009
Kenmore 64952 Electric Dryer Logo
Popular Tags
50 questions posted
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Dryers
  • Kenmore Dryers
Most Popular Question
kenmore elite electric dryer runs gets
  • Dryers
