20 Most Recent
Kenmore 72115 Air Conditioner Questions & Answers
High speed setting of fan does not work
If your motor only works on low speed and not on high speed first check to see if you have the proper voltage to high speed. Check with a voltmeter or multimeter, check from common on the motor to high speed on the motor at the switch. If you have the proper voltage then you have an open winding on high speed and the motor needs replaced. If you don’t have the proper voltage or any volts, then the switch is bad and needs replaced. This also will be the same if, medium speed won’t work and low speed does.
Kenmore Model 970-438321
Without a serial number you cannot look up on line what the unit age is. Have you cleaned the condenser coils on the bottom and back of unit?
