FixYa.com
Kenmore 17228 Grill
All Products > Kenmore > Grills and Smokers
Problems with Kenmore 17228 Grill?
Search inside Kenmore 17228 Grill Knowledgebase
Troubleshooting and Support
Solved Problems for Kenmore 17228 Grill RSS Feed Post a New Problem
Propane Regulator Adjustment
I have a Marshall Gas Controls propane regulator Model 230 installed on a sailboat and I need to increase the discharge...
2 Solutions
jenn air 32 in. 4 burner gas grill
I put a replacement propane tank on and the burner lights for about 2 seconds then goes out. It does the same when I try...
1 Solution
b.q.grill
can a natrual gas grill be use with propane gas
1 Solution
weber charcoal grill repair
The flanges that close the vents on my platinum one touch weber grill have bent, and no longer close the vents. I am...
1 Solution
gas line and codes
I have a natural gas grill. I want to run a gas line from the meter to the grill. Does the gas line need to be buried or...
1 Solution
Fire Magic won't lite
2 weeks ago I installed a 36" Fire Magic Echelon with a searing station. It is difficult to lit and sometimes wno't...
2 Solutions
jenn-air grill
I just bought this grill----Jenn_Air Model No-720-0336 and the rotisserie burner keeps going out after it gets hot.
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Kenmore 17228 Grill RSS Feed Post a New Problem
grill won't heat to high enough temp.
The grill will light but just won't get very hot
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
TypeGrill
Fuel TypeNatural Gas
Cooking Area608 sq. in.
Ignition TypePush-button igniter
Other Features
BTU'S per hour40,000 BTU
WheeledWheeled
Dimensions
Depth21 in.
Height49 in.
Width65 in.
Weight156 lb.
Warranty
Warranty1 Year
Kenmore Contact Information
Main support number1-800-KENMORE
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
