20 Most Recent Kenmore 700 sq. in. Cooking Area Gas Grill 14116325 Questions & Answers
check / replace the gas regulator
not passing the gas
Kenmore 700 sq.... | Answered on Nov 12, 2017
clean the spider webs out of gas lines .
Kenmore 700 sq.... | Answered on May 15, 2016
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Kenmore 700 sq.... | Answered on Feb 20, 2015
I had this same problem especially when the tank on my 5 burner 2 year-old Kenmore was about half full. The solution above fixed it. I was used to opening the gas fully, turning one burner to high and clicking the button. If I would have read the front of the grill I would have seen that this was incorrect. I turned off the grill completely, unhooked the regulator and reconnected it. With one burner on high I began clicking the button BEFORE I turned on the gas. I slowly turned the gas on one quarter turn and it lit up full flame. I slowly turned the gas another quarter turn and lit the second burner. I slowly opened the gas all the way and lit the third and so on. That did the trick!
Kenmore 700 sq.... | Answered on Apr 06, 2012
This will sound crazy but, when the grill and gas is off have you looked underneath to make sure the gas valves are aligned to the burners? moving a grill around can dislodge the burners then the gas will not eneter the burner or the burn box as designed. think putting a bic pen back in it's cap. this is the relationship of the back of the valve to the burner
If these are aligned....
at the point where the valve meets the burner there is an opening, a venturi if you will. Bugs love these holes. spiders make nests in them, wasps and hornest make nest in them, you name it. if it is blocked with a nest the gas flows backwards and you have fire where you don't want fire. start there. Most Grills are made to easily remove the burners once the grates are off or if you look up from the ground level you can see in there (this is the path air takes to feed air to the burners. last if you have a cabinet you may need to open the doors and look up that way.
Good luck happy grilling and be safe
Kenmore 700 sq.... | Answered on Jul 15, 2011
More than likely, the electrode spark ignitors on your main burners need to be cleaned. They will get covered with grease over time. Also check the wiring from the ignitor module to each spark ignitor being sure that all wiring is firmly in place. To clean the electrode(s) ... a cotton ball dipped in alcohol will work fine.
Hope this helped you solve the problem and Happy Grilling!
Kenmore 700 sq.... | Answered on Apr 09, 2011
Hi, The only safe fix is to replace that regulator...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Kenmore 700 sq.... | Answered on Oct 22, 2010
Try going to Barbecues Galore, they should help or try the natural gas filling shop, they specialize in gas grills and components, also.
Kenmore 700 sq.... | Answered on Oct 06, 2010
You problem could be or probably is with the regulator...not enough gas pressure...
heatman101
You problem could be or probably is with the regulator...not enough gaspressure...
heatman101
Kenmore 700 sq.... | Answered on Sep 20, 2010
Replace the hose and regulator if this is an LP grill...... or just the regulator if this is a NG grill.
Kenmore 700 sq.... | Answered on Jul 12, 2010
Kenmore 700 sq. in. Cooking Area Gas Grill 14116325 Logo
47 questions posted
Top Kenmore Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Grilling
  • Kenmore Grilling
Most Popular Question
kenmore 4 burner grill purchased
  • Grilling
