20 Most Recent
K2 Cinch CTC Snowboard Binding Questions & Answers
K2 Cinch loop leash on top of highback tore. What
The K2 website has a binding technical manual, link was found at the bottom of the K2 home page (see link below). The manual provides NO part numbers and NO repair procedures, but the repair is fairly easy.http://assets.k2sports.com/k2snow/ftpk2snow/2017/catalogs/k2snowboarding_binding_tech_manual.pdfThe back straps on the K2 Cinch are called "grab loops" as shown in photo below.If both “grab loops” are broken, take a few photos first so you can recall the routing for installation of the new “grab loops”.These "grab loops" are held in by two silver coloured roll pins which can easily be tapped out with a small nail & hammer. If the pin doesn't come out easy, tap from the other side of the pin. The pin has a head on one side.You may need to use pliers to remove the broken piece of strap from the top lever.Take the broken strap pieces to your K2 retailer ( snowboard shop) and ask them to order a new strap. K2 info suggests you can’t order parts online direct from K2, so you have to order through a K2 retailer.Use your other binding with the good strap to copy the routing of the new strap. You might want to order two new grab loop straps and change them both while you are at it. ??
Require a new bracket that holds the cable on the
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Rear leg high back comes undone/releases when i pop
It sounds like either one of two things, with the high back. Take the adjuster off and check the teeth to see if it is stripped. If it is, Go to your local hardware store and pick up some locktite epoxy. It will be a permanent bond, but that will make them usable. The other chance is maybe it needs to be torqued down. With the possibility of your foot popping out that sounds like you bindings are not set up correctly. I had a pair hit a rock off a bc kicker, ripped the adj, off. and still was securely held down. If you are not sure how to set it up, hit up your local board shop
Wearfit 2.0. Why can't I bind to my iPhone?
Discord users facing issues like
How To Fix Discord Not Opening so just make a call on Discord Customer Support 1-802-618-6092 anytime and experts are there on Discord Live Chat to help you 24*7 . Need any kind of guidance to fix the Discord issue so just make a call on Discord customer Service 1-802-618-6092 anytime and fix issues, a helpdesk is there to help you 24*7
