20 Most Recent
Bowflex Xtreme 2 Se Gym Questions & Answers
My cable pulleyes are twisting the cable up on
I had the same problem, came up with a fix: all you have do is put a zip tie ( panduit, tie wrap) on the pulleys. Install the zip tie so the top and bottom pulleys are loosely linked. this stops the bottom pulley from rotating 360 degrees (thus twisting the cable).
I have bowflex extreme 2. Power rods hit the
I called Bowflex and they said there is a Lower Lat Tower Upgrade (Part 001-9704) that fixes the problem for $106.10. Seems like a design defect to me, not an upgrade. Regardless, I have not purchased the part yet to see if it fixes the problem.
I just got a bowflex extreme 2 from someone used.
The nice thing about the Xtreme 2 is the fact that you do not need to change cables for different exercises, but it does mean numerous cable position adjustments depending on the exercise you are doing. To alleviate the slack problem in the cables you can either have the cables that run under the seat remain attached to the leg extension attachment or move the sliders attached to those cables as far forward as possible thereby pulling the cables as far out as they can go. This will both increase the resistance provided by the rods and keep the floating pulleys from hitting the lat pulley housing.
I keep getting error code 0AB
Error code 0AB on a Fisher & Paykel refrigerator may indicate a problem with the evaporator temperature sensor. The evaporator temperature sensor is responsible for monitoring the temperature inside the freezer compartment. If the sensor is not functioning properly, it may send incorrect temperature readings to the control board, causing the error code to appear.
Some possible causes of this error code include:
- The evaporator temperature sensor is malfunctioning and needs to be replaced.
- The wiring connections between the sensor and the control board are loose or damaged.
- The control board itself is malfunctioning.
If you are seeing this error code, I would recommend checking the wiring connections and the sensor and if they are ok then the control board may need to be replaced.
It is best to contact a qualified technician or the manufacturer for help troubleshooting and repairing the issue, as working on refrigeration equipment can be dangerous if you are not properly trained and equipped.
My question was about the bowflex ct5000 step climber piston shocks leaking why?
The hydraulic shocks found on exercise machines aren't very different to the shocks found on cars, bikes and trucks or even inside some washing machines - the ones on display on bikes and exercise machines are better finished and nicer to look at.
Your question is asked everyday by thousands of vehicle owners who also want to know why shocks leak.
I have a theory, but it is just a theory - If a telescopic shock absorber is going to leak they mostly start leaking while relatively young. I think very few leak because the seal is worn out - a very few do and that happens after a long service life.
I think in some cases it could be the quality of the seal or the way it is fitted but my theory is about the ambient temperature, the temperature of the components and the temperature of the oil that fills the shock.
It is possible during manufacture a certain volume (rather than a weight) of oil is placed in each shock and at certain times, such as first thing after the weekend, in the winter perhaps, the oil will be cold so when the finished item meets hot weather the fluid expands and the level could rise enough to overwhelm the seal...
Bowflex tc5500 circuit board error code D status R23 red
www.treadmillpartszone.com
You must locate to side from the power switch you must find the fuse holder and replace the fuse with THE SAME SIZE+CAPACITY+VOLTAGE INDICATED FROM THE SAME FUSE.
Remember if the fuse is Blown again or continuing you have a short circuite in a) Transformer b) Main Motor c) Main Controller Board d) Faulty ground in your receptacel from the wall very carefully.
attached the block diagram that I did for to illustrate to person like you, good luck. sincerely.
