20 Most Recent GIMP GNU Image Manipulation Program Questions & Answers
go to control panel display and do the resizing then in the pixel settings
GIMP GNU Image... | Answered on Feb 12, 2018
I don't know if this will help and all and I had to search up what tarpaulin and a few things came up and I honestly dont know how big you wan't it but Im going to give it a try
1 pixel = 0.0008680556 feet
But if im wrong I would just search it up on google for converters, Im sorry im not much help even though I use gimp daily
GIMP GNU Image... | Answered on Apr 02, 2015
Judea I do not know the answer to your question and I know it's a little late but hi my name is Jordan DeMaris I hope you remember me. Keep your head up and study hard little sis, your always on my mind.
GIMP GNU Image... | Answered on Jul 19, 2014
I receive the same error, but only when opening or saving a file while a removable drive is attached to the computer (typically my camera's CF card). Naturally this is annoying when processing new photos. I don't have a solution to the underlying problem, but I do have a workaround for the annoying pop-up message. It involves using Windows Registry Editor, so use at your own risk.
1. Start Button -> Run
2. Type "regedit" without the quotes
3. Proceed through the following entries (double-click each name:
HKEY_LOCAL_MACHINE -> SYSTEM -> CurrentControlSet ->
Control -> Windows
4. Locate "ErrorMode" and double-click
5. Change the entry for "Value Data" from 0 to 2
6. Change the entry for "Base" from Hexadecimal to Decimal
7. Click "OK"
8. Press F5 to refresh the Registry Editor
9. Close all windows and restart your computer
Again, this will stop the pop-up messages warning you that there's no disk, but it doesn't solve the underlying problem. If you're comfortable that there's nothing actually wrong with your computer (I am) this will at least make GIMP usable again. Thanks to jamuma on answers.microsoft.com for the original idea.
GIMP GNU Image... | Answered on Feb 27, 2013
It is impossible to import a word document file into GIMP, but it is possible to COPY the text in the document and PASTE it onto a text layer in GIMP. This, unfortunately, destroys the formatting (for instant, tabbed spaces are removed for paragraph beginnings.)
Please contact me at div.ceslum@gmail.com if you have any other questions regarding text layers in GIMP.
GIMP GNU Image... | Answered on Jan 15, 2013
To open a photo in GIMP, simply open GIMP and when the blank GIMP Workspace appears, click and drag your picture from wherever it is saved (ie: from your Pictures Folder) into the GIMP workspace.
On my computer, when gimp stops operating, its normally because its processing something. When the splashscreen pops up, it'll often freeze for almost a minute while its initiating.
It also freezes when I try to render a large image, or apply a filter to a large image. I can always just wait it out.
It shouldn't take more than five or six minutes, if it takes that long and still refuses to work, uninstall and reinstall. If the issue persists, download a fresh copy of the latest version of GIMP and install that.
GIMP GNU Image... | Answered on Jan 14, 2013
You may repair .psd files with the aid of
fix corrupt psd file
program can't modifying your original .psd file data during restoration
GIMP GNU Image... | Answered on Apr 27, 2012
You will need work under RGB mode and add a new layer to coloring there.
GIMP GNU Image... | Answered on Feb 27, 2012
In the window with the picture you want to copy, choose Select/All and then Edit/Copy. In the window where you want to put it, create or select the layer into which you want to put it, then choose Edit/Paste. You can then move, scale, and whatever.
GIMP GNU Image... | Answered on Feb 22, 2012
GIMP GNU Image Manipulation Program Logo
134 questions posted
Top GIMP Computers & Internet Experts
Rick Moore
Rick Moore
Alun Cox
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a GIMP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • GIMP Computers & Internet
Most Popular Question
import word text into gimp
  • Computers & Internet
