on my tips and tricks page are links to owners manuals for Schwinn and Huffy. they are all the same, Those respective websites with the links have clear instructions on quick releases.
Your quick release has three parts 1. shaft with lever 2. nut 3. springs x 2
Take the lever apart, remove the nut and both springs. install one spring large side onto the shaft all the way up against the lever side, slide the shaft through the hub axle center, install the other spring on the shaft opposite the lever small side facing the hub, then screw on the nut. look to the video for the rest.
Standard WD40 is just a 'quick fix' as it isn't an actual oil unless the can is clearly labelled as "Bike All Condition Lubricant". It'll be best to buy a proper light oil like 3in1, 151 Super oil or an actual chain lube.
This 'clickey' noise. Is it random and happening every so often or is it a constant, regular click that changes with the speed your pedalling at? Check for slack in the chain. as you wiggle the chain up and down there should only be about a centimetre of movement in the chain. If it's too slack or too tight it can make strange noises. Check the axle bolts and nuts to make sure they're not loose. Check the wheel is mounted straight. If it's turned left or right the chain will 'skip' as it's slightly missing the cog teeth on the wheel. Use the frame at the rear end of the wheel as reference and measure how far the side of the wheel is from the frame on both sides. It should be about the same both sides.
I have done a tremendous amount of research on this problem. New Balance (Fitness Quest) is out of business as of late 2012 and no parts are available. The main bearing or crank bearing set is 100% compatible with Proform part number 295560. Since New Balance put their name on this product, they have stated they will reimburse customers for the repairs.
Il est possible de trouver un manuel pour le v?lo Genesis GS52686 V2 100 en visitant le site web du fabricant ou en contactant directement le fabricant pour demander un manuel. Il est ?galement possible de trouver des informations sur ce v?lo sur des forums de discussion ou des sites web sp?cialis?s dans les v?los. Il est recommand? de v?rifier si le manuel est disponible en ligne ou de demander une copie imprim?e aupr?s du fabricant. Il est important de noter que les r?glages de la fourche de suspension et de la suspension arri?re peuvent varier en fonction du poids, de l'exp?rience et des pr?f?rences de conduite de chaque cycliste. Il est recommand? de consulter un m?canicien ou un expert en v?los pour obtenir des conseils sur les r?glages appropri?s pour votre v?lo.
I own this particular Old Fashioned bike -lol - its a hardy one thou and I dont think you can find the original book but the book that came with it came from the company Roadmaster Corp. which is now named Roadmaster Industries, Inc - 250 Spring Street NW - Atlanta, Georgia 30303 -- phone number -- (404) 586-9000. I hope this helps ya. My resource came from the website that tells all about the cpy. http://www.fundinguniverse.com/company-histories/Roadmaster-Industries-Inc-Company-History.html
So good luck in finding your manual. I am pretty sure that they can help after all they made this bike originally in 1992,
That depends on what you are using it for. Obviously, if you are dirt biking, you should use a dirt bike, and otherwise use a street bike. Start out with what you are going to use the most - dirt (freestyle) or street racing.
