20 Most Recent Topeak Joe Blow Ace Floor Pump Questions & Answers
Gauge needle not moving, still pumps air into
You can buy a replacement gauge from topeak web site.
8/7/2019 3:53:07 AM • Topeak Joe Blow... • Answered on Aug 07, 2019
The needle on my joeblow
Probably not user accessible. Get a replacement gauge from the manufacturer: https://www.todson.com/collections/small-parts or contact them at: Todson Inc 4 Cocasset Street Foxboro, MA 02035 USA Tel: 800-213-4561 ext.1 Email: [email protected] https://www.todson.com/pages/contact
2/3/2019 3:19:49 AM • Topeak Joe Blow... • Answered on Feb 03, 2019
Joe blow pro manual
Contact the manufacturer: Todson Inc 4 Cocasset Street Foxboro, MA 02035 USA Tel: 800-213-4561 ext.1 Email: [email protected]
2/3/2019 3:04:13 AM • Topeak Joe Blow... • Answered on Feb 03, 2019
Guage needle fell off joe blow pro pump
Had the same thing happen. It turns out you can pry off the plastic ring around the dial, then remove the clear plastic window. I did that and just stuck the needle back on at 0.
6/4/2014 7:04:57 AM • Topeak Joe Blow... • Answered on Jun 04, 2014
In a Joe Blow Sport
Try re-greasing the O-ring on the end of the pump rod.
11/7/2013 2:03:59 AM • Topeak Joe Blow... • Answered on Nov 07, 2013
Does not seem to be pumping air
Most likely the O-ring has worn out, but first take it apart by unscrewing the top of the cylinder where the sliding rod goes thru. Then look at the working end of the rod (opposite end from the pump handle), and put some light grease on the O-ring (it is a black rubber ring), reassemble and test it. If it still doesn't push air out, take the O-ring to a hardware store for a replacement. This usually solves the problem.
11/7/2013 1:59:04 AM • Topeak Joe Blow... • Answered on Nov 07, 2013
0answers
Cannot get my brand new
Change the internal parts of the head to adapt to the valve type you're using.
http://www.bikenewyork.org/resources/nuts_bolts/tires.html
1/23/2011 3:07:04 PM • Topeak Joe Blow... • Answered on Jan 23, 2011
Topeak joe blow pumps front but not rear tire
What's different?
http://www.youtube.com/watch?v=Ehf6HL0aLTc
http://www.ehow.com/how_4779541_inflate-bicycle-tire-presta-valve.html
  1. Rotate the wheel so the valve is resting just above the floor. Remove the valve cap.
  2. Unscrew the locking nut on the valve stem. Quickly press down the stem to loosen the seal. You should hear air escaping when the stem is pushed in--if you do not, loosen the nut and try again.
  3. Press the pump head onto the valve and flip the locking lever to make a seal. You'll hear air escape, but it should stop after you've locked the lever. If air continues to leak out, remove the pump head and reattach it.
  4. Make two pump strokes and listen for air moving into the tire. If the pump handle becomes hard to press down after only a few strokes, or if the pressure gauge elevates extremely quickly, remove the pump head and repeat Step 3.
  5. Inflate the tire to its recommended pressure. Remove the head by unlocking its lever and quickly pulling it off the valve stem. Secure the valve's locking nut and cap.
Read more: How to Inflate a Bicycle Tire With a Presta Valve ' eHow.com http://www.ehow.com/how_4779541_inflate-bicycle-tire-presta-valve.html#ixzz1Brv5VfAX
1/23/2011 2:31:34 PM • Topeak Joe Blow... • Answered on Jan 23, 2011
The pressure gauge on my
Presta Compressor Toolwww.prestaflator.comInflate Road or Mountain Bike Tires Accurately in Seconds!
1/23/2011 2:28:13 PM • Topeak Joe Blow... • Answered on Jan 23, 2011
I have fitted the pump
For starters, I assume that you pushed the lever away from the valve -- if not, that is your problem. Other potential problems are: a worn gasget in the head or a valve stem that is not fitting properly. I had the bad valve stem and when I put in a new tube the problem was solved.
1/18/2011 7:17:10 PM • Topeak Joe Blow... • Answered on Jan 18, 2011
I cannot figure out how to attach football
Older model pumps screw in. Newer models get inserted and then you either push the lever down or pull it up to lock onto the threaded end of the needle
11/12/2009 4:39:01 AM • Topeak Joe Blow... • Answered on Nov 12, 2009
My almost new JoeBlow Turbo pump won't seal on either type stem
Do you flip up the lever on the air outlet? It should be flat on the handle to insert on the valve stem and then flipped up to lock on.
Hope,
matt
9/16/2009 1:57:52 AM • Topeak Joe Blow... • Answered on Sep 16, 2009
My Joe Blow Pro will only pump up to about 40 to
Most likely a problem with the check valve - try this: "Make sure the Check Valve at the bottom of the pump is inserted correctly. Unscrew the rounded nut just above the foot rests, pull out the spring and black thingy. The pointy black thingy (check valve) must be inserted first, pin in first, then spring behind it, then small black rubber O ring. One of my four kids (or me?!) must have switched it, because spring first. it would not pump (bounced back and gauge said zero after every pump). Put it in black valve first, and it worked like new. If this does not work for you, it is possible that you need a new check valve, about $3." Joe Blow Sport Floor Pump Problems I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
9/14/2017 6:35:56 PM • Topeak Cycling • Answered on Sep 14, 2017
Topeak Joe Blow Ace Floor Pump Logo
Popular Tags
20 questions posted
Top Topeak Cycling Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Tony Parsons
Tony Parsons
Are you a Topeak Cycling Expert? Answer questions, earn points and help others
View Most Popular
Topeak Cycling
  • Topeak Cycling
Most Popular Question
gauge needle not moving still pumps air
  • Cycling
