20 Most Recent
Airstrike Bell 1800 Floor Bike Pump Questions & Answers
I have a "Judge"
Sure, A new O-ring and a little grease, the same you use on your bearings to make a good seal.
Without seeing and feeling the actual pump, a sloppy O-ring will cause a loss of pressure.
You will also want to check the head and make sure the rubber still makes a seal around the tube valve, if not then that will need to be replaced as well.
The tubing that leads from
Most Bike Shops carry repair kits for common pump brands and I wouldn't be surprised if some cross brand parts would work. eBay has many for sale.
"floor pump hose"
You might even be able to go to an automotive supply store and get some pressure hose yourself real cheap.
How do I use the Bell AirStrike Digital Floor Pump
The gauge measures three different amounts. Be certain that you have it set to PSI. Then set the target PSI. The green LED indicator will then flash when you are within
5 PSI of your target and will flash constant when the target PSI is
reached.
Need new hose
Has anyone found a replacement hose for the Airstrike 1900? And/or instructions on how to replace it?
Should I add oil to the top opening (where pump
It's not the opening that is the culprit. Those bell bicycle pumps have an o-ring for a piston seal, and this ring needs oil from time to time. The oil that should be used is as thin an oil as you can find, something like 3 in 1. You should disassemble it to check to see if the plastic piston isn't cracked. (They do crack from time to time, and might be what is wrong with your pump.)
Tomahawk E Series Exercise bike loud peddling sound
Standard WD40 is just a 'quick fix' as it isn't an actual oil unless the can is clearly labelled as "Bike All Condition Lubricant". It'll be best to buy a proper light oil like 3in1, 151 Super oil or an actual chain lube.
This 'clickey' noise. Is it random and happening every so often or is it a constant, regular click that changes with the speed your pedalling at? Check for slack in the chain. as you wiggle the chain up and down there should only be about a centimetre of movement in the chain. If it's too slack or too tight it can make strange noises. Check the axle bolts and nuts to make sure they're not loose. Check the wheel is mounted straight. If it's turned left or right the chain will 'skip' as it's slightly missing the cog teeth on the wheel. Use the frame at the rear end of the wheel as reference and measure how far the side of the wheel is from the frame on both sides. It should be about the same both sides.
9/22/2023 12:16:04 PM •
Cycling
Answered
on Sep 22, 2023
