20 Most Recent Kenmore 53552 / 53554 / 53559 Questions & Answers
Its possible that the door switches or one of them is not being activated by the doors and could require adjusting if adjustment is an option. Look into this first, seems to me its a good possibility that it could be the fault.
Kenmore 53552 /... | Answered on Oct 10, 2019
The compressor is trying to start and does not...
If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Kenmore 53552 /... | Answered on Sep 25, 2010
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Kenmore 53552 /... | Answered on Sep 18, 2010
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Kenmore 53552 /... | Answered on Jul 13, 2010
IF THE ICE MAKER IS OVERFLOWING, THE ADJUSTMENT SCREW WON'T HELP. ON MODULAR ICE MAKERS, THE BIG
WHITE GEAR ON THE FRONT BEHIND THE COVER HAS CIRCUIT TRACES ON ITS BACKSIDE THAT WILL ARC, BURNING THE PLASTIC GEAR, BRIDGING THE FILL CIRCUIT WITH ANOTHER TRACE, MORE THAN DOUBLING THE FILL TIME. THE MODULE NEEDS TO BE REPLACED. (GEAR IS NOT AVAILABLE BY ITSELF).THE MODULE IS THE SQUARE PLASTIC ASSEMBLY MOUNTED TO THE FRONT OF THE ICE MAKER WITH THREE SCREWS. INCLUDES THE MOTOR.
Kenmore 53552 /... | Answered on Mar 27, 2008
this unit does not have a hot gas def system but rather a pulsed def where the heater will kick on for a few minutes every so often to see how frosted up the coil is. the draw back is that they are having problems with the control board keeping the compressor and condensor motor on during the def cycle, thus ending up with a solid ice build up in the coil..
Kenmore 53552 /... | Answered on Dec 23, 2007
replace the compressor start relay should fix it for you.
Kenmore 53552 /... | Answered on Dec 15, 2007
the relay is bad. get pt#8201786 and replace it according to the instructions in the box and your all done. this is a very easy repair. cost for the relay should be less than 60 bucks.
take back off freezer from the in side check for continuntity on your heater and therm make sure your therm. is cold
Kenmore 53552 /... | Answered on Dec 13, 2007
All have a pan located under the evaporator core. The drain hole is located at the lowest point in the pan.
Occasionally the hole will freeze up with ice and not flow.
Defrost the fridge for two days and this will usually open the tube. Use care when working with electrical appliances.
Kenmore... | Answered Yesterday
Thermistors input temperatures to the control boards. Thermistors may have a 2k Ohms value at 70° F, a service manual or guide, or look up part number for replacing any thermistor out of range.
Kenmore... | Answered 3 days ago
To have the model number would be very helpful to give you the correct information.
https://www.searspartsdirect.com/manual/1fse6xozod-000582/kenmore-10677188791-top-mount-refrigerato
Kenmore... | Answered on Oct 14, 2019
Is there a fan in the refrigerator which draws cold air from freezer. If so is fan working, if fan not working may be faulty fan or thermostat. May also be blocked duct from freezer to refrigerator, only there if fan is used as above.
Kenmore... | Answered on Oct 03, 2019
How doyou change the filter
Kenmore... | Answered on Oct 02, 2019
The bar will sense ice cube level in the holding bin. If it is all the way down it will tell the ice maker to make more ice. When the maker "dumps" the ice the bar should be all the way up and will lower to check the level.
Kenmore... | Answered on Sep 22, 2019
Kenmore 53552 / 53554 / 53559 Logo
21 questions posted
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Refrigerators
Most Popular Question
least 3 4 inches solid ice bottom fre
  • Refrigerators
